Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Mar 31, 2019 13:28:17 GMT -8
Eager to see the progress photos! 😀
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Apr 18, 2019 14:37:01 GMT -8
Started working on the camper again.
I took a metal single folding step that I got at harbor freight and cut about 2 inches off the legs and now i have a very nice 15 dollar step so I can enter the camper.
I cut the plastic surround finisher to length for the ceiling exhaust fan
I decided I need to finish the trailer tail light wiring. Hook up the 7 pin cable and box. Plug it into the truck and no running lights. Got brakes and blinkers but running no running lights. Started testing and found I must have put a screw into that wire. I did find one spot but it still seams to be an issue. Now I have to track down the short.
shastatom
Post by shastatom on Apr 20, 2019 14:55:35 GMT -8
I got the 54 out of storage today. Summer is here and I don't care what the rest of you say but I have to believe the good weather is here now. Winter was to long in Minnesota.
I did some work on the 58. -Go the door catch attached -Got the bunk bed brackets back up -Started polishing the metal on the wings. I have the original wings. I now just need to polish and put them back together. I have to get all the silicone off the metal.
Had to get the house ready for easter so didn't much more accomplished.
Everyone have a good easter tomorrow.
shastatom
Post by shastatom on Apr 24, 2019 17:25:34 GMT -8
Nice day so I was able to do some work.
Items that got done: - fixed the short in the tail lights - started the wiring for the 12 volt battery
shastatom
Post by shastatom on Apr 28, 2019 15:47:57 GMT -8
Couldn't work on the camper yesterday. It was snowing.
Today Worked on the awning for the 54. Got it sewn and the grommets installed. Ready for summer.
FInished the 12 volt wiring in the 58 and got the 110 volt wire connected.
shastatom
Post by shastatom on May 21, 2019 17:17:20 GMT -8
I haven't done an update in a while.
I now have the 110 volt wiring done, cleaned up the wiring and got it all put away. So the 110 and 12 volt wiring looks good.
Got the outside water box installed and the inside water box figured out as well as the grey water tank.
Started cleaning up the underside of the camper and got the curbside wheel well trim on.
Put another floor support under the door walkway to firm up the floor.
Things left to do: - trim the inside dining side windows - trim the joints inside - finish the fresh water and grey water - gas lines - test the stove, oven, heater and gas light - finish the trim on the streetside - paint the underside and tongue - put up the curtain rods - get my wife to do her magic and sew new curtains - get the bed cut and installed - install a battery box - wife wants me to put new laminate on
Forgot the most important item, install the wings
I am out of picture space so no pictures to post.
shastatom
Post by shastatom on May 22, 2019 17:49:33 GMT -8
Ruffed in the fresh water pipes and pump. Polished the old faucet. Figured out how I wired for the pump. That seemed to take most of the night.
shastatom
Post by shastatom on May 23, 2019 18:17:49 GMT -8
Got the fresh water tank installed, the fresh water lines clamped with the pex tool, drilled some holes in the floor for the grey water line. Hope to be able to test it out with a couple more hours of work.
shastatom
Post by shastatom on May 26, 2019 18:36:35 GMT -8
Today I got some work done:
Got the grey water lines done and tank installed Got the freshwater done and fixed the leaks after testing
Big item, I got wings installed.
Things left to do: - trim the inside dining side windows - trim the joints inside - gas lines - test the stove, oven, heater and gas light - finish the trim on the streetside - paint the underside and tongue - put up the curtain rods - get my wife to do her magic and sew new curtains - get the bed cut and installed - install a battery box - wife wants me to put new laminate on - fix the screen door - sew the vinyl for the benches - put fake bottoms in the upper cabinets and the cabinet over the dinette
For every item I remove I seem to find 2 more things to do
shastatom
Post by shastatom on May 28, 2019 17:57:31 GMT -8
Tonight I worked on the old floor heater but didn't seem to get it started or working. So I moved the the oven/stove and that lit right up. I then worked on the base for the stove/oven and then got busy doing something else.
Things left to do: - trim the inside dining side windows - trim the joints inside - gas lines - test the heater and gas light - finish the trim on the streetside - paint the underside and tongue - put up the curtain rods - get my wife to do her magic and sew new curtains - get the bed cut and installed - install a battery box - wife wants me to put new laminate on - fix the screen door - sew the vinyl for the benches - put fake bottoms in the upper cabinets and the cabinet over the dinette - hang the scissor jacks under the camper
Like I said, take one item off and add another.
Here is a link to the photos of this project photos.app.goo.gl/5aq2uKZT7ECy3V9H3
shastatom
Post by shastatom on Jun 4, 2019 17:37:09 GMT -8
Got a few more items started or done: Gas lines got the screen door taken apart and ready to put back together Installed battery box and new battery
Things left to do: - trim the inside dining side windows - trim the joints inside - test the heater and gas light - finish the trim on the streetside - paint the underside and tongue - put up the curtain rods - get my wife to do her magic and sew new curtains - get the bed cut and installed - wife wants me to put new laminate on - fix the screen door - sew the vinyl for the benches - put fake bottoms in the upper cabinets and the cabinet over the dinette - hang the scissor jacks under the camper - mount and paint the bumper
debranch
Wee Camp
71 Shasta Compact
Post by debranch on Jun 4, 2019 17:46:32 GMT -8
I agree with you about the list... I keep my list in my Alexa list on my phone and as the completed list grows the list of things to do never really gets shorter. Maybe one day it will... Debra
shastatom
Post by shastatom on Jun 12, 2019 18:04:41 GMT -8
Fixed the screen door and screen door middle slide section and got it reglued. Now putting shellac on it. Got the wood that I am going to use to cover the gaps in the walls and ceilings sanded and ready to shellac Got the gas light working and fixed the leaky brand new hose I bought, got a new hose. took about 2 hours and cleaned out all my tools, extra parts, wire, gas fitting, water fittings, old bed, vacuumed and got it cleaned up inside.
Everything seems to take twice as long to do this year versus 2 years ago. I think everyone is getting old and not able to keep up anymore. I am glad I am not one of them......!!!!!
IF you want to see pictures go here photos.app.goo.gl/5aq2uKZT7ECy3V9H3
Things left to do: - trim the inside dining side windows - trim the joints inside - finish the trim on the streetside - paint the underside and tongue - put up the curtain rods - get my wife to do her magic and sew new curtains - get the bed cut and installed - wife wants me to put new laminate on counter and table - fix the screen door - sew the vinyl for the benches - put fake bottoms in the upper cabinets and the cabinet over the dinette - hang the scissor jacks under the camper - mount and paint the bumper
shastatom
Post by shastatom on Jun 15, 2019 12:14:16 GMT -8
Today before the rain storm hit us I got the following done:
3 out of 4 scissor jacks mounted Wife got some more curtains made I got the bed cut and installed
Things left to do - trim the inside dining side windows - trim the joints inside - finish the trim on the streetside - paint the underside and tongue - put up the curtain rods - get my wife to do her magic and sew new curtains - wife wants me to put new laminate on counter and table - fix the screen door - sew the vinyl for the benches - put fake bottoms in the upper cabinets and the cabinet over the dinette - mount and paint the bumper
I now have a time line. I have to be done for camping by mid august.
Post by mel on Jun 15, 2019 14:28:48 GMT -8
How did the scissor jacks install go? I was thinking about putting some on my Airflyte. Would love to see a few photos on where you install exactly and how they work out after you have used them
