shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Jun 17, 2017 16:01:48 GMT -8
Today after losing 2 days of work I got the following done: Got final coats of varnish on the wardrobe and remaining ceiling boards Built the convection microwave cabinet Primed the bumper Test fit the microwave and stained the cabinet 20170617_151249 by Tom Ress, on Flickr
shastatom
Post by shastatom on Jun 19, 2017 3:50:20 GMT -8
Got quite a bit done this weekend. - Got another ceiling panel up - Wardrobe is ready to install - Kitchen cabinets are stained and ready for varnish - To change things up I took the buffer out and started buffing the kitchen drawer pulls, hinges and locks as well as one window frame. You can see some of the before and after on the handles, hinges and window. 20170618_094033 by Tom Ress, on Flickr 20170618_133559 by Tom Ress, on Flickr 20170618_192041 by Tom Ress, on Flickr 20170618_214121 by Tom Ress, on Flickr
shastatom
Post by shastatom on Jun 19, 2017 18:49:23 GMT -8
Today I got some more supplies. -Ordered the vinyl for the seats -Birch for the doors I have to make -plywood for the bed -insulation -and a few other items needed for the camper. What I figured out was I am sort a few parts. I need your help in were to find these parts 2 Shasta hinges and 1 latch bracket see pictures below. 20170619_210252 by Tom Ress, on Flickr 20170619_210552 by Tom Ress, on Flickr
shastatom
Post by shastatom on Jun 21, 2017 4:18:49 GMT -8
Got some work done last night: Got the fabric for the benches Put varnish on the kitchen lower cabinets Build the fake wall in the wardrobe for ventilation for the fridge. Helped my brother build the frame for one of the cabinets Cut the plywood for the bed Polished some more hinges and brackets and almost forgot I put a panel in the front of the fridge 20170620_172326 by Tom Ress, on Flickr
shastatom
Post by shastatom on Jun 21, 2017 15:18:46 GMT -8
Today I had other items on my list so I only got some varnishing done and a bit more painting.
shastatom
Post by shastatom on Jun 23, 2017 4:00:27 GMT -8
Progress report: Last night it was very humid so I couldn't varnish but I did get the kitchen lower cabinet sanded for final coat.
I took the roof metal down and measured it to the ceiling and figured out where the fan vent will go. That took a lot of my time.
Started wiring. Got the 7 pin ran into the location where all the wiring will go Got the shore power plug wired Got the start of what needs to go where in the fuse box.
Brother came out and worked on the upper cabinets
No real pictures to show today. I am hoping this weekend gets me a few steps further.
I am looking for a good wiring plan for a 7 pin wiring, with a battery for power and a fuse box with 12\110 power. I think I know what to do but need to confirm it with another wiring diagram that I understand.
shastatom
Post by shastatom on Jun 25, 2017 4:54:46 GMT -8
Every time I think the end is getting closer I realize there are lots of details or work that needs to be done that takes forever. Today I got the following done: Got the 110 and 12 volt wiring and a gas line run to the refrigerator Started running wire for the outlets Got the outlet run for the microwave and future AC unit Got the kitchen cabinets mounted and the top plywood and masonite cut Brother got one of the upper cabinets sanded down and we cut the holes for the lights and he got some of the skins on the other cabinet I am trying to get items done that need to get done before I can put the skin back on, we booked our first camping trip for July 14th. That is my motivation to get things or at least enough done so we have a place to sleep. 20170624_215913 by Tom Ress, on Flickr 20170624_215844 by Tom Ress, on Flickr 20170624_215918 by Tom Ress, on Flickr
Post by ladywendolyn on Jun 25, 2017 6:00:39 GMT -8
RinTin
Post by RinTin on Jun 25, 2017 6:02:01 GMT -8
Every time I think the end is getting closer I realize there are lots of details or work that needs to be done that takes forever. I think it was John Palmer, when he used to post on the forum, that said the last 10% of the work takes 90% of the time. That has certainly held true for me. Looks like your plan is coming together nicely, well done.
Post by mel on Jun 25, 2017 18:57:10 GMT -8
I have the same goal as you, our first trip is booked July 13th. Fingers crossed were both ready by then Yours is looking awesome as usual, I love seeing your progress.
shastatom
Post by shastatom on Jun 26, 2017 3:53:08 GMT -8
Yesterday I continued to wire. I now have wire run for everything but the front lights. I also need to go back and clean up some of the wiring and tack it down. Boy my hands hurt. I have lots of little cuts and I feel like my fingers are stiff and swollen. Wiring is not one of my favorite items. All the 110 volt is done and my wife wants to know were she is going to plug in her toaster. One of my friends told me I should put a light under the bed for when I can't find that whatever that has slid to the back of the storage area. Here is a picture of the switch and a puck light I will use. 20170625_201112 by Tom Ress, on Flickr Here you can see the water pump, 110 outlets, and the pipe going across to the wardrobe with other wire. This will be hidden by a access door under the bed between the kitchen cabinet and wardrobe. 20170625_201128 by Tom Ress, on Flickr This last picture shows the fancy reading lights that will be at the bed. 20170625_201043 by Tom Ress, on Flickr I forgot to paint the bottom of the refrigerator shelf so I have to take that apart again and paint. Oh XXXXX! Oh well. Have lots of clean up to do on my grounding strip. Lots of wires to long and the strip needs to be fastened down. I may need to take a couple days off of work to get done on time. I don't look forward to puddy removal.
Post by vikx on Jun 26, 2017 20:31:04 GMT -8
I like your floor better every time I see it, Tom. Just beautiful. Oh, and thanks for including the proverbial *foot* even if it had a shoe on it...
Post by michaelaj99 on Jun 26, 2017 20:55:09 GMT -8
hi there, enjoying this! I just purchased my first trailer-a basket case 1954 Shasta as well. can you share a good source for the appliances and other bells and whistles you mention? thank you mj
shastatom
Post by shastatom on Jun 27, 2017 3:54:32 GMT -8
Last nights progress report: First things first I got a foot in one of the photos can you find it. Did a tool round up and put stuff away Got more wiring done Cleaned up the wiring Took the fridge out and painted the box - I forgot to do that and got ahead of myself Mounted the wardrobe Redid the gas line into the fridge box - wasn't happy with my first attempt Put the door and hardware on the lower kitchen cabinet Pulled out the porta-potty and it fits in the reserved location for the AC if I ever decide to put one in. See 3rd picture for location. Under the microwave. Brothers progress: Got another panel glued to the upper kitchen cabinet and sanded the rest of it 20170626_215223 by Tom Ress, on Flickr 20170626_215203 by Tom Ress, on Flickr 20170626_215430 by Tom Ress, on Flickr 20170626_215441 by Tom Ress, on Flickr I was just thinking I never post pictures of brothers work so here you go. 20170626_215325 by Tom Ress, on Flickr
Post by michaelaj99 on Jun 27, 2017 19:47:47 GMT -8
Tom, I see you HAVE the exterior up! Did I miss that photologue somewhere? Would really like to see how you did that.
