RinTin
Post by RinTin on May 31, 2017 5:24:38 GMT -8
So you want to increase the width of the bed from 4' to 4'-6"? No reason you can't, you seem to have a good handle on the trade-offs. I left mine the original size. My wife thinks we'll fit, I'm 6' and my wife is 5'7". I think we'll be sleeping separately. If we end up wanting a bigger bed, I'll get a bigger trailer.
shastatom
Shasta 54,57 1500 58,59 Airflyte
Post by shastatom on Jun 1, 2017 5:45:57 GMT -8
Talked with the wife and she says stay with the normal layout and the 3/4 full. Do as the boss says. Last night my brother came over and helped take apart the top kitchen cabinets and started sanding them. I built one of the booth bench boxes. Cleaned up the garage again and started the build of the other booth box. As you can see the booth box doesn't have the slide panel. That is because I am putting a fuse box in the front of it and the slide wouldn't work. I need to start vanishing stuff soon because that takes several days to dry and put on coats between drys. Tonight I think I will finish the booth box and cut out the kitchen window. Maybe put a coat of varnish on a ceiling panel so I can put it on the front wall/ceiling. Make it look like I did something. 20170601_070021 by Tom Ress, on Flickr
Post by ladywendolyn on Jun 1, 2017 18:29:45 GMT -8
One thing that people do is that they build a little jut out piece that sits between the cabinets and allows the bed to stick out into the isle a bit. So it makes the bed bigger when needed. This photo shows one in a situation in a sonnets where the issue was a curved table, but the same principle applies and you can rig a piece that pulls out a bit and has an extra piece of foam and so the bed is wider in the middle where needed. .
shastatom
Post by shastatom on Jun 2, 2017 4:08:53 GMT -8
Last night I was able to do a few things: -Cut the kitchen window in -took the axle off and lowered the camper to some dollies - the fresh water tank will need to come off to get the camper out the door -got 2 coats of varnish on the ceiling boards, table and other misc boards -brother came over and worked on upper kitchen cabinets some more
My biggest fear is that I goofed up with my measurements and the skin and openings will not match up. I guess new skin would then be needed. Maybe not a bad thing because I wouldn't need to then do all that polishing.
shastatom
Post by shastatom on Jun 2, 2017 19:08:35 GMT -8
Date night so not much done. Just bought more stuff for tomorrow when i pour money down this endless hole. If I didn't know any better I would say I own a boat. (god forbid)
Really things are getting better, I just need to have everything here so I can keep moving or do the measurements I need to keep building.
Post by ladywendolyn on Jun 3, 2017 22:14:23 GMT -8
It's like childbirth shastatom the only way to stop the pain is to finish it! Your doing an awesome job!
shastatom
Post by shastatom on Jun 4, 2017 18:32:01 GMT -8
This weekend I got a few items done. =got final layers of varnish on some ceiling boards -got the second booth base cut and stained. ready to build -calked the wall and frame - waxed the floor 4 times It was a good weekend even though I had to stop early today since it was the wifes birthday. 20170604_102107 by Tom Ress, on Flickr 20170604_103537 by Tom Ress, on Flickr
Post by ladywendolyn on Jun 4, 2017 20:30:07 GMT -8
Looks amazing
Post by mel on Jun 5, 2017 3:40:46 GMT -8
Wow, your moving along so quickly. It looks great so far, love seeing your progress.
shastatom
Post by shastatom on Jun 6, 2017 4:26:27 GMT -8
Forgot to take a picture but did the following: -Got the fuse box cut into the bench seat -Took the wardrobe apart and started planning on its rebuild -Brother came over and continues to work on the upper kitchen cabinets -Did a tool roundup and put away -Found that the box I bought for the tongue is to big -Put up some more supports along the ceiling -Filled in the space next to the front window -Fixed my air stapler -Got the window for the door I ordered - didn't want to put just glass in again and watch it leak so I bought a small window with a frame to put in the door. -Fixed the garden sprinkler for the wife
Didn't get a lot of view-able work done but it was another good night.
Tonight is work on the new wardrobe cabinet and varnish more wood
shastatom
Post by shastatom on Jun 6, 2017 18:49:58 GMT -8
Didn't get much built because it was a great night to do varnish. Did have to remake one of the seat base fronts. I measured wrong but cut right. Of course the measurement was 1 inch to big so the hole was to big for the CO2 detector. -Varnished, drawer fronts, bottom kitchen cabinet, seat bases, some of the front window stuff and table stuff -Painted the bottom door jams for the door and storage door as well as the front bottom board Here are some pictures of the seat bases mocked up and the front of the camper 20170606_193718 by Tom Ress, on Flickr 20170606_205731 by Tom Ress, on Flickr
sherrifriend
1967 Compact Shasta
Post by sherrifriend on Jun 7, 2017 4:35:52 GMT -8
Hey tom, Did you stain the subfloor? Curious to learn some more about your water-damage preventative plan.
shastatom
Post by shastatom on Jun 7, 2017 5:59:39 GMT -8
Hey tom, Did you stain the subfloor? Curious to learn some more about your water-damage preventative plan. I used soundboard with tar on one side, calked the seams and 2x3 board tops when putting it down then put a layer of tyvex down and then painted the plywood with oil based paint. When I put the side walls on I then calked the edges and 2x3 boards and put the wall on. I also did that when I started putting the front wall on. I then paint with the oil based paint anything that is going to be exposed on the bottom. I also offset the sound board seam and the plywood seam so there wasn't any one seam going across the middle of the camper from bottom to top. Not sure this is always right but trying to keep water out but if it does get wet it also need to be able to dry. That is the trick. The other piece that is important is to get a good seal around the wheel well.
sherrifriend
1967 Compact Shasta
Post by sherrifriend on Jun 7, 2017 6:56:57 GMT -8
Are the bottoms of your very pretty walls mounted flush with the bottom of the frame (wheel well etc.), then attached, then painted with oil based paint around the bottom edges?
shastatom
Post by shastatom on Jun 7, 2017 9:37:22 GMT -8
Are the bottoms of your very pretty walls mounted flush with the bottom of the frame (wheel well etc.), then attached, then painted with oil based paint around the bottom edges? See pages 2 and 3 for some pictures of frame and walls but walls are mounted to sides of the 2x3 floor joists. I then painted the wall framing that is exposed under the camper. You will see an image on page 3 of the wheel well but I painted from front to back underneath the wall frame and edge of the plywood wall Here is a better picture of a wheel well more finished 20170526_215903 by Tom Ress, on Flickr the ridge you see down the middle is the sheet metal from the wheel well. My skin will cover most of this anyways but want to make sure the bottom of the board is some what protected.
