kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Nov 28, 2017 12:23:14 GMT -8
Just trying to get things straight...I will be making my curb/edge boards out of (3) 1/4" strips of plywood. My question...do you glue/staple these 3 strips together BEFORE attaching to the framing? Or do I attach one strip to the trailer, then add 2nd one with glue/staples and clamp...later add 3rd strip and glue/clamp? Does that make sense!? Just wondering if glueing all 3 strips together before attaching makes it harder to bend? Thanks for your patience with my myriad of questions!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/126814716@N02/38658143152/in/dateposted/" title="IMG_0625"><img src="https://farm5.staticflickr.com/4522/38658143152_6396170466_z.jpg" width="480" height="640" alt="IMG_0625"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Nov 28, 2017 16:20:01 GMT -8
Don't glue before you put it on the camper. You wouldn't be able to bend it then. I think you need to find Mobiltec videos on how to do this.
Post by nccamper on Nov 28, 2017 18:21:43 GMT -8
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Nov 28, 2017 19:15:40 GMT -8
Thanks !! I think I got it now. And I meant 1/4" thick plywood- so 3 of them together makes the curbing 3/4" thick. I had planned on making them 1" wide. Make sense? Thanks again- that helped a lot ! kathy
Post by mobiltec on Nov 30, 2017 18:57:54 GMT -8
Thanks !! I think I got it now. And I meant 1/4" thick plywood- so 3 of them together makes the curbing 3/4" thick. I had planned on making them 1" wide. Make sense? Thanks again- that helped a lot ! kathy Just make sure your staples stay centered on the 3/4 inch wide framing and don't go outside those measurements. Don't want staples poking down inside the trailer.
