57heaven
Post by 57heaven on Oct 12, 2022 17:45:14 GMT -8
Does anyone know where I can find a finished mattress in a 48" x 80"? Thanks
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Oct 12, 2022 17:58:01 GMT -8
I had to have one made by a local mattress maker.
57heaven
Post by 57heaven on Oct 13, 2022 7:26:41 GMT -8
Tom did you have one made from a place that has numerous locations around MN?
shastatom
Post by shastatom on Oct 14, 2022 18:43:40 GMT -8
Post by Hamlet on Oct 15, 2022 7:38:46 GMT -8
Also you can look for a supplier of firm upholstery grade foam and have them cut it to sixe.. Add a couple mattress pads and you will have a comfortable bed.
Post by nccamper on Oct 16, 2022 19:03:38 GMT -8
I bought a full size foam mattress and cut it down.
Post by wisconsinjoe on Oct 28, 2022 8:27:25 GMT -8
You can definitely cut down a larger foam mattress. I recommend using a jig saw with a KNIFE blade that zips right through cleanly. You might have to cut through both sides, but with accurate measuring and marking with a Sharpie, it should be easy.
The advantage here is that you can actually try out the comfort level of a bed first, potentially before buying (like at Costco). We had mattresses custom made from the Foam Factory online, and although they did a good job, we found them too firm and had to add softness on top. An added expense.
Post by nccamper on Oct 28, 2022 15:45:36 GMT -8
When cutting down the mattress you just need to be careful about how you open up the cover (from the side)so you can resew it.
shastatom
Post by shastatom on Oct 30, 2022 15:01:17 GMT -8
I used my wifes electric knife and used 4 2x4s and clamps to squeeze the foam so I could do it in one cut.
