olesaka
Post by olesaka on Dec 20, 2021 15:44:13 GMT -8
Do any of you only have a 120v system? We will only camp where shore power is available. Deciding if we should go with both systems or if 120v will be just fine.
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Dec 20, 2021 17:48:18 GMT -8
I seam to only camp with 120v power but I wired lights, refrigerator, co2 detector, vent fan and water pump for 12 volt for just in case and also because the fridge I wanted needed 12 volt for computer power.
We talk now about boon-docking and that is possible because of the 12 volt system.
Post by nccamper on Dec 21, 2021 7:25:08 GMT -8
Ultimately we all end up off the grid sooner or later. Often public campgrounds only have so many electric sites. And we all stop at rest stops where a light is helpful on a dark, rainy day. I wired for both and use the 12 volt more than you might expect.
I suggest at least running the wires for both while the walls are open. Wire is cheap and you can always decide later.
Post by wisconsinjoe on Dec 21, 2021 9:13:17 GMT -8
This is what I did: I have all lights, fridge, fan and some outlets wired for 12 volt DC, meaning that power will always come from the battery. But, since that battery has a Converter/Charger hooked up to it, that battery power is constantly replenished when the camper is plugged into shore power (120 volt AC). I also have several regular "house" outlets (120 volt) that are functional ONLY when plugged into shore power. So, that gives me the ability to boondock, limited only by the amp hours of my battery system. When boondocking, I can't plug my space heater, device chargers, toaster, blender, etc in because that only works for shore power 120 volt AC. I can charge devices (phone, etc) on the 12 volt system outlets. So, basically, if I can live without heat or appliances, I can boondock for the time allowed from my battery power. If I want heat, I have to plug into shore power. If I have to charge up my battery, I have to find shore power to plug into or connect to a generator, which I never do or want to do because of the noise. I do monitor my battery voltage and make sure I don't drop below the level safe for my battery.
Incidentally, on my first trailer that had ONLY 120 volt AC shore power, I disconnected the wire system from the AC source that powered four different light fixtures. I then rerouted the incoming AC shore power to a converter/charger (and then to the battery) as well as some AC outlets. Then, I connected the battery to the old 120 volt AC wires, thus now sending only 12 volts DC. I replaced all of those regular house current (120 volt) light bulbs with new 12 volt LED bulbs. They make them with the same old style screw in bases. Of course it is also important to send those hot 12 volt wires from the battery through a fuse block, sized appropriately to the size of the wires.
Because of those energy efficient LED bulbs, I now get the same amount of light (measured in "lumens" with about 1/10 of the energy use, thus saving battery power. The old AC wiring that now carries only 12 volts is overkill, but safe.
Post by vikx on Dec 21, 2021 12:27:56 GMT -8
Very few vintage trailers had a 12 volt system. There was sometimes a ceiling light run when the parking lights on the vehicle were on or run by a small 6 volt battery close by.
I would definitely wire for both since the walls are open. Fantastic Fans are very nice to have as is a water pump. Light is important when it's dark...
That said, it's not impossible to wire later without taking the trailer apart. I like having new wiring in place, but it can be done.
aslmx
Only 120V
Dec 21, 2021 18:32:10 GMT -8
via mobile
Post by aslmx on Dec 21, 2021 18:32:10 GMT -8
I’ll probably do some 12v stuff but if I’m going where I have no power , I can always use led lanterns, DEWALT 20v fan and yeti cooler keeps things cold for a few days.
Poquito
Post by Poquito on Dec 27, 2021 5:34:06 GMT -8
The big thing for me as a FL gal is having a fantastic fan when boondocking. My current camper is all 120 with a vent fan on inverter, a portable Rigid fan that is electric or chargeable battery and no water tank just fresh and Grey water Jerry cans on a hand pump system, & battery operated lights when off power grid but I did have a camper with solar panel attached / battery charged wiring for the fan, lights, and pump. It was like having a Prius as apposed to my Carolla. So since my old camper is already wired for 120 with the fan on an inverter, I will be adding a portable solar panel with a Jackery charger to use when going out west. Switching out the fan for a Fantastic Fan (so much nicer and quieter) an external water tank to keep in the back of the truck with a pump and also portable hanging shower bag that has it's own pump / shower handle. I agree you should consider wiring for 12v because you never know when you or a possible new owner would want that option in the future. Add on: heat so far has been not an issue because it rarely gets below 40 inside at night during winter in FL, however I do have a buddy heater that I have yet to use. (Bought two years ago) having a large dog helps with the one dog nights. Tip: flannel sheets and a foam insulation under that mattress helps keep the bed toasty at night. Poquito
Post by turbodaddy on Dec 27, 2021 6:24:59 GMT -8
Hello all, Hope everyone is having a great, safe and healthy holiday season. I did much same as Joe. I think by not providing a complete 12vdc system you pretty much eliminate being able to enjoy the quiet solitude and natural beauty that can only be experienced off the grid for several days, at least. For our family, that is always what we strive for when camping.
These places are hard to find in the Northeast, but are plentiful out West and in Canada. Many, if not most, of the best campgrounds we've stayed in do not provide any hookups. Usually there is a water spigot and outhouse within walking distance, and a dump station near the park entrance. There is hardly anything more satisfying than having the ability to stay warm and comfortable, with lights, stove and (propane) refrigerator out in the middle of nowhere. Happy trails in 2022!
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Dec 27, 2021 18:38:51 GMT -8
I think by not providing a complete 12vdc system you pretty much eliminate being able to enjoy the quiet solitude and natural beauty that can only be experienced off the grid for several days, at least. For our family, that is always what we strive for when camping. These places are hard to find in the Northeast Oh, how we loved Baxter State Park...
