idaho211
Post by idaho211 on Apr 12, 2020 8:04:37 GMT -8
Post by vikx on Apr 12, 2020 10:53:13 GMT -8
I used clear shellac on my 57 Deluxe. We sanded the panels but couldn't get the "white" streaks to disappear so decided to remove it. If your finish is rough and flaking, the solution is to scrape it. We used Buck plane blades (Home Depot): 013 Scraping Shellac (3) by vikkx, on Flickr Sharpen the blades often. Scrape with the wood grain. 013 Scraping Shellac (2) by vikkx, on Flickr 013 Scraping Shellac (1) by vikkx, on Flickr Makes a mess but easy to vacuum or sweep. The trick is to get all the old finish off and sand lightly. Any white streaks will show thru, so be sure the wood looks even. Amber shellac will cover a multitude of sins but your trailer is a lot lighter as my Deluxe was. Clear is closer to the original finish. Hopefully others will chime in on the varnish issue. I thought mine was shellac because it scraped so easily.
Post by nccamper on Apr 13, 2020 9:53:06 GMT -8
Looks like Shellac to me. Did you soak a rag with denatured alcohol and wet and area to see it it dissolved and became gummy? Even 60 year old shellac will become gummy. Poly won't.
I think Shasta used shellac but over the last 60 years people re-coated most campers with polyurethane. I've sanded a couple of campers but it's a miserable job.
Post by vikx on Apr 13, 2020 11:54:39 GMT -8
I never tested for shellac but sure seemed like it..
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Apr 13, 2020 14:02:08 GMT -8
I would guess clear shellac. I sanded all of mine off, it is an terrible job and took me days and then I re-coated with an amber - clear shellac combo and I still got some streaks in it from the old shellac but I think I use a gallon of clear and a quart of amber and that was a nice compromise. My problem was the old shellac yellows and you can never seem to find a match.
Good luck.
idaho211
Post by idaho211 on Apr 19, 2020 15:18:10 GMT -8
Thank you all for the advice.
