shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Oct 22, 2020 16:19:47 GMT -8
Tonight I got the tail light wiring run, tacked down the wires on the outside of the camper, and stared putting the strips on the edge but found that I need to cut some more plywood strips.
shastatom
Post by shastatom on Oct 27, 2020 17:36:49 GMT -8
Well with snow on the ground and her car windows needing to be scraped every morning, I have lots of pressure to get the camper out of the garage. I have the sides insulated and started putting the wood strips on the edges. Happy wife happy life, isn't that what they say. 20201026_211040 by Tom Ress, on Flickr
shastatom
Post by shastatom on Nov 3, 2020 18:09:20 GMT -8
Tonight I finished gluing the insulation down and wrapping the camper in tyvex. I also got hold of my storage guy and he is ready for the camper. I just need to pull the camper out when I can take it to storage in the same day. I will need to pull it out and put the axle and tires back on and pull it over. I can then give the garage back to the wife. 20201103_200115 by Tom Ress, on Flickr
Post by vikx on Nov 3, 2020 21:53:52 GMT -8
All wrapped for Christmas...
Post by nccamper on Nov 4, 2020 15:45:21 GMT -8
This may have been covered somewhere on this excellent thread. But when you're done do you have to pull off the frame and slide the camper out the way it went in? Or just the axle as you stated above? What if you added 1/2"?
shastatom
Post by shastatom on Nov 4, 2020 18:57:07 GMT -8
Right now the axle is off and it is sitting on some dollies and the angle iron. I will lower it to the ground and see if I added any additional height. (I hope note because the original tin will not fit then) So if it is taller I have a couple of options. First remove the rubber seal strip. That will give me .5 of an inch. Second I could remove the cedar trim board and that would give me another .75 of an inch. I will put some 1x2 or 1x3 on the driveway and try and get them to take most of the load once I get it off the smooth garage floor.
shastatom
Post by shastatom on Nov 9, 2020 6:30:23 GMT -8
It is official. The camping season is over for me as well as working on the camper body. Here you can see the camper making its first road trip to storage. I got lots of looks as I was driving this one down the road. It came out of the garage without an issue. I must have planned it well. Screenshot_20201108-133336_Snapchat by Tom Ress, on Flickr Posts will slow down now since I will most likely be polishing parts and doing other prep work for next year.
Post by nccamper on Nov 9, 2020 8:07:43 GMT -8
Thanks. This is a great thread.
57 Trotwood
Post by 57 Trotwood on Nov 12, 2020 5:36:24 GMT -8
Thanks. This is a great thread. Your photo reminds me of when you see a photo of a new car driving around with all types of masking decals when a manufacturer tests drives a car. People were probably saying, "Hey I bet that's one of those new Retro Shastas I have heard about" Have a good winter.
shastatom
Post by shastatom on Dec 8, 2020 18:52:14 GMT -8
Since I had nothing better to do I pulled the windows, eye brows, and interior window frames out of the shed and started cleaning them.
I got the windows taken apart and the 60 year old butyl tape off. After 60 years most of it was still flexible and soft. This is why I like using butyl tape because it stays soft for a long time.
I started cleaning the eye brows. I had to do quite a bit of work on straightening and reshaping from all the dings and dents they got over the years.
I probably got another 40 hours of work of cleaning and polishing. Great winter project.
adderall
Post by adderall on Feb 18, 2021 14:03:32 GMT -8
Shastatom, was your vinyl flooring click lock? How was it secured in place? I was trying to send a PM on here but I couldn’t figure out how.
shastatom
Post by shastatom on Feb 18, 2021 18:16:04 GMT -8
Shastatom, was your vinyl flooring click lock? How was it secured in place? I was trying to send a PM on here but I couldn’t figure out how. They are Armstrong® Flooring Standard 12 x 12 Commercial Vinyl Composition Tile and glued down.
shastatom
Post by shastatom on Feb 28, 2021 17:14:49 GMT -8
Now that it is't 20 below zero I started working on the camper eyebrows again.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/147439784@N03/50990463843/in/dateposted-public/" title="20210228_132421"><img src="https://live.staticflickr.com/65535/50990463843_525cbb4f53_z.jpg" width="640" height="360" alt="20210228_132421"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
shastatom
Post by shastatom on Apr 22, 2021 16:30:11 GMT -8
It is official, winter is over. I went and got the camper and put it back into the garage.
aslmx
Post by aslmx on Apr 23, 2021 17:38:22 GMT -8
Can’t wait to see the progress. The wife and I are still making arrangements to come see you in the near future.
