shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Sept 6, 2019 18:07:35 GMT -8
Good evening everyone. I wanted to share my new project for next year.
I just bought a 57 Shasta 1500.
Vin c8976 for those of you who like to know this stuff.
The camper is in pretty bad shape and will be a bit of a challenge getting it home. I will need to do some reinforcement on the inside first and a corner of the metal is peeling off.
So why would I buy one in such bad shape. Well I guess I have a soft spot for the Shasta 1500 since my first camper was one of these. Also if I need to do a frame off restoration it may as well be for a camper that is rare and hard to fine.
I guess I will log my progress from getting the camper to the demolition to the rebuild. I have all winter here in Minnesota to formulate my plan.
At a minimum it will be a frame off, new 12 and 110 volt wiring and fuse box, LED lighting, other safety items. The real question will come down to if I put a real camper fridge in or leave the ice box and if I put in hot water like I did my 54.
In my signature I have loaded a link to the pictures I have so far of the camper. She may not be much to look at right now but if it comes out as nice as the 54 or 57 I will be happy.
So why I am in planning mode now is the time for you to give some ideas, input and advice. Just remember I am not new to the rodeo and this will be number 3 for me. So telling me I am crazy will not much effect me.
Everyone have a good night and hope to give you updates as I go.
Post by nccamper on Sept 6, 2019 19:23:13 GMT -8
It’s great. Perfect.
PT
Post by PT on Sept 6, 2019 20:17:13 GMT -8
Great project.
Anyone that restores these trailers is at least a little crazy but it keeps us from going insane ;-)
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Sept 6, 2019 22:44:44 GMT -8
I applaud you bringing another one back to life! Go-man-go.
shastatom
Post by shastatom on Oct 6, 2019 17:10:53 GMT -8
Today was the big day. I got up at 5:30 in the morning and was on the road by 6. Drove 4 hours to Duluth Minnesota. The guy I bought the camper from was there with his dad and they helped me get the new tires on, stuff taped up and supports put in place for transport. I was done with all of this in 2 hours and back on the road. Got home by 6 safe and sound.
My trip was pretty much uneventful other then a light camper being blown around by a pretty good wind.
See my signature link for pictures.
Post by mobiltec on Oct 19, 2019 18:35:42 GMT -8
It's a fun little camper to restore. Looks like it's all there.
Post by nccamper on Oct 20, 2019 4:14:39 GMT -8
Sorry about the hijack, but while looking over your threads I was stopped by this Airflyte photo... That's a Houdini miracle! How did you fit it in the garage?
New meaning to "Lowrider" You pushed it in on 1x8 lumber?
shastatom
Post by shastatom on Oct 20, 2019 16:16:41 GMT -8
NCCamper
You can fit in a 7 foot high door if you take the camper to the ground, pull off the roof vent and then push it in using a chain and the truck. You have about 1/8 of an inch to spare.
Post by nccamper on Oct 20, 2019 18:37:50 GMT -8
You have about 1/8 of an inch to spare. My mistake, I thought it was a tight fit...
Post by mobiltec on Oct 21, 2019 12:42:26 GMT -8
NCCamper You can fit in a 7 foot high door if you take the camper to the ground, pull off the roof vent and then push it in using a chain and the truck. You have about 1/8 of an inch to spare. May as well be a foot. Proves that where there is a will there is a way.
shastatom
Post by shastatom on May 2, 2020 16:47:15 GMT -8
Hi everyone, well it is official, the project can start. It took me about 90 minutes to get the axle off and the camper pushed into the garage.
I would have started a couple weeks ago but I spent that time insulating, sheet rocking and building shelving in the garage o I can work longer into the fall. I also spent the day cleaning out the portable garage so I can have some place to put parts. Attached is a photo of the project. The plan is to do a frame off. May the project begin.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/147439784@N03/49848305332/in/dateposted-public/" title="20200502_094930"><img src="https://live.staticflickr.com/65535/49848305332_8a63baffc3_k.jpg" width="2048" height="1536" alt="20200502_094930"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
shastatom
Post by shastatom on May 4, 2020 16:29:48 GMT -8
Today, I removed the eye brows, windows and doors. I decided to stop for the day because I had to remove so many of the screws by hand. I sure am glad I had the fancy must have pliers.
Since I have 2 other trailers the urgency isn't as great but I do need to keep moving. Take stuff apart moves pretty fast.
shastatom
Post by shastatom on May 5, 2020 17:19:01 GMT -8
Trying to be good and work on the camper some everyday. Todays work: Cleaned up the inside some, took spare, extra stuff out of the camper and put it in the tent Took off 200 screws , c rail, street side drain rail and corners. There isn't much left in the corners but rotted wood. One trick I found when taking out screws with the drill, put the screw bit in the screw, manually tighten and loosen the screw if it turns then go ahead and use the drill to power it out. I found if I did this almost 90% of all screws came right out. When I wasn't doing this I stripped out the screws. Here is a photo of the back of the camper, you can see there isn't much wood left in the corners. 20200505_193916 by Tom Ress, on Flickr
shastatom
Post by shastatom on May 6, 2020 17:54:51 GMT -8
Tonight I got the following items done: Removed the back metal Removed the front metal The wood was pretty much gone on the front and back Got all the nails out of the roof and ready to take it off There just isn't much left for a pattern in the corners. It will be interesting to get this one put back together. 20200506_193628 by Tom Ress, on Flickr
Post by nccamper on May 7, 2020 3:36:32 GMT -8
I've always loved the rot reveal. Amazing it held together towing home.
Nice fleet in the background.
