kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jul 7, 2018 19:21:36 GMT -8
The original countertop laminate was a tad thicker than the new stuff I installed. Today I put the metal trim back around the sink- and it sits high off of the countertop due to the thickness difference. Was thinking of caulking- but don't think that's the best solution. Think I can bend the lip down that sits on the counter so that the gap disappears? How best to do that? Really don't want to remake the trim- as it is in great shape, just a little off. Thoughts?? IMG_3744 by kathy, on Flickr
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Jul 7, 2018 19:26:10 GMT -8
Maybe cut a 1/8 of an inch off the bottom of the trim or maybe you can bend the angle past 90 degrees.
Post by vikx on Jul 7, 2018 19:35:03 GMT -8
The only thing I can think of is putty tape to fill the gap, under the flange, then caulk the edges very neatly. Even silicone might work in this case; it's easier to smooth than other caulks. Practice a lot before caulking. There's no hurry and you want it perfect.
CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on Jul 7, 2018 19:53:02 GMT -8
I had the same problem, filled with putty tape but don't really care for the look. I like the idea of caulking, will do that. Thanks vikx Also just as an added solution. I found this product at www.americantechnologyinc.com/product-category/seamfil/ It's a product made to fill the seams or damage in formica. Since it's called Seamfil, maybe it could be used to fill the space after putty. The advantage is that it's colored to specifically match your laminate. Not sure it would work in this application but might be worth checking out. After checking this website out further, they also sell color matched caulk.
Post by danrhodes on Jul 7, 2018 20:26:10 GMT -8
Most plumbers would use plumbers putty there. I did under mine and probably should have used clear silicone for a nicer appeance
Post by vikx on Jul 7, 2018 20:31:06 GMT -8
I like Tom's idea, but wow, you'd have to be a precisionist to trim 1/8 and make it look good...
charliemyers
Post by charliemyers on Jul 8, 2018 3:51:59 GMT -8
kaffi311 Do you mind sharing what trim you purchased? I need to order some soon for a new counter top & trimming the sink hole just like yours.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jul 8, 2018 14:13:26 GMT -8
kaffi311 Do you mind sharing what trim you purchased? I need to order some soon for a new counter top & trimming the sink hole just like yours. Hello I did not get new trim- it's what was originally around the kitchen sink. In good shape- so reusing. Thanks all for the ideas- I will let you know what I did!
