humorme
1967 Shasta 1500
Post by humorme on Feb 21, 2015 9:31:35 GMT -8
humorme
1967 Shasta 1500
Post by humorme on Feb 21, 2015 9:42:02 GMT -8
The first day it traveled about 30 miles to my parents house. Then the next morning it traveled the final 45 miles home. We live in the middle of Atlanta and didn't want to try to haul it during Friday rush hour. Good thing, because 2/3 of the street side wall came detached on the journey home. Thankfully we had added some bracing and duct tape to the back before we tried to move it. Otherwise it would have ended up scattered across the interstate. This was back in November.
humorme
1967 Shasta 1500
Post by humorme on Feb 21, 2015 10:03:59 GMT -8
With no garage or shelter to work under, we put up a temporary carport and I built a hoop house to store supplies and work in. The hoop house hasn't work out as well as I had hoped. I ended up enclosing the temporary carport in tarps and plastic and doing all of the work in there. Not sure how its going to go when its time to add the new panels to the walls, but I'll figure something out.
Post by vikx on Feb 21, 2015 22:06:34 GMT -8
Looks like you have your work cut out but you CAN do it.. Takes time and reading. Will enjoy seeing it become a trailer again.
humorme
1967 Shasta 1500
Post by humorme on Mar 17, 2015 7:19:00 GMT -8
humorme
1967 Shasta 1500
Post by humorme on Mar 17, 2015 7:33:29 GMT -8
The front was in bad shape too. I found the first evidence of a prior attempt at repair. A piece of flat iron bar was added to the cross member that supports the dinette table.
humorme
1967 Shasta 1500
Post by humorme on Mar 17, 2015 7:40:12 GMT -8
Removing the curb side skin revealed the bulk of the previous renovation - there were steel mending plates and angle brackets everywhere. Everywhere! But, at least they're easier to remove than staples. I also figured out why the breaks in the skin didn't line up across this side of the trailer. The door had been reframed out of square.
Post by vikx on Mar 17, 2015 20:53:50 GMT -8
Lots of Brackets!
Anytime metal is touching the aluminum, they can cause some pretty severe metal rot. Aluminum does not like to be married to steel...
Glad you took it apart and will be fixing it right.
Post by Hamlet on Mar 18, 2015 18:29:18 GMT -8
All those brackets are a hoot! Guess the PO didn't know that aluminum and pot metal don't mix.
humorme
1967 Shasta 1500
Post by humorme on Apr 20, 2015 20:48:00 GMT -8
After repairing the curb side wall, it was time to strip it down to the frame. No more roof: No more walls: No more floor:
humorme
1967 Shasta 1500
Post by humorme on Apr 20, 2015 20:55:51 GMT -8
Time to get the frame cleaned up Leaf springs and axle removed. While the axle was off, moved the spring perches. Axle sitting over the spring left me with only about 4" of ground clearance. Now, with the axle under the springs, I have about 8". Frame all primed and painted. Finally starting to feel like I'm moving in the right direction.
Post by vikx on Apr 20, 2015 20:56:50 GMT -8
Good Work and fun to see!!
humorme
1967 Shasta 1500
Post by humorme on Apr 20, 2015 21:03:14 GMT -8
Installing the floor joists. Check out those shiny new electric brakes
jodybitzz
1968 Shasta 1500
Post by jodybitzz on Apr 21, 2015 18:15:01 GMT -8
This looks SO familiar!! We are just now finishing our frame off rebuild on a 1968 1500. It's taken us over 1.5 years. ( I have a thread with all the pics.) Good luck, I can't wait to see how it goes.
Ken
68 shasta 1500
Post by Ken on Apr 22, 2015 6:01:25 GMT -8
Looking good!
