stephanie
1966 Kit Companion
Post by stephanie on Feb 9, 2015 19:36:33 GMT -8
Good evening!!! I just bought my 1966 Kit Companion yesterday. The man I bought it from informed me there is a small leak on the roof (He said it was coated a few years ago) and it's leaked into the closet inside the camper. Now, I understand that money will have to be spent on remodeling projects such as this....but is there any product that isn't overly expensive that I can use to redo the roof? This is a whole new experience for me....this is my first camper ever lol....so any help and tips are very very appreciative!! Thanks!!!
Post by SusieQ on Feb 9, 2015 20:03:07 GMT -8
Here is great thread from our Admin about sealing roof seams. It was written assuming the original seams have not been gooped. vintagetrailertalk.freeforums.net/thread/1599/roof-seams-when-sealing-necessaryWhat is on the roof currently? You probably don't want to hear this, but this group is not fond of roof sealer products, or goop, as it is referred to here. The other thing (bad news) that you need to be aware of is - if the seams leak or have leaked in the past, you probably have rot that you cannot see. The water runs down, of course, and the skirt boards (the boards along the bottom of the frame) rot. You can use Mobil's ice pick method and get under it and poke around to see if you have rot or soft spots but the only sure way to know is to remove the skins. If it is leaking from the roof seams, you could have rafters or other framing boards with water damage or rot. This could be leaks that have not necessarily left a watermark inside but has run down the back or front and ends up in the corners. Check the front and back corners and the wheel wells. If you are looking for a quick fix for a leak, I'm sorry to say, you're probably not going to find it here. But there is a lot of great info on how to repair and restore your trailer properly here.
stephanie
1966 Kit Companion
Post by stephanie on Feb 9, 2015 20:29:24 GMT -8
Thank you!!! This is why I signed up....to find things like this out. What I'd LOVE, to be honest, is someone who knows about this kind of stuff here in Houston, that I can talk to in person, one on one....but thank you for responding SusieQ!!!!
Post by mobiltec on Feb 9, 2015 21:11:38 GMT -8
Thank you!!! This is why I signed up....to find things like this out. What I'd LOVE, to be honest, is someone who knows about this kind of stuff here in Houston, that I can talk to in person, one on one....but thank you for responding SusieQ!!!! Well I suppose I could move to Houston. Are ya single? LOL... I don't know how many people we have in your neck of the woods but I think there are a few. However what SusieQ told you is the truth. There is no easy cheap fix for a leaky roof. No matter how much goop you put on it the thing will continue to leak because the aluminum expands and contracts with heat and cold. That severs the bond between the goop and the aluminum almost immediately. The goop remains but allows water under it in places. Especially on the roof. The roof also vibrates as you move because of the wind traveling over it. If the leak is because of a vent then all you need to do is remove the vent and re-seal it with new putty tape. If it is in the corners it is probably due to the need for new putty tape under the J Rails. That trailer probably needs a complete re-seal anyhow. They all do at that age. It's pretty simple and not expensive at all. New screws and a few rolls of putty tape is all you need for this. The tools are a screw gun and a couple of screw drivers. Seams do not normally leak. If they do, then you need a new roof. If the leaks are due to holes from hail damage or tree limbs, then you need a new roof. That's not that hard to do either really. I've had many viewers both male and female who have installed a new roof by following my videos... You may wish to take a look at those. They are on my website.
Post by Hamlet on Feb 10, 2015 19:23:59 GMT -8
Welcome to our madness! And don't get discouraged by what you have read. We really aren't a bunch of gloomy doomsayers. We just want to make sure that when folks get into these old trailers, they realize that almost all of them (80% or more) have structural issues, and all of the ones that have not been recently restored at least need new butyl tape in the seams. This requires removing lots of screws as well as the J-rail. So as long as you've gone that far, you may as well go ahead and lift the skins to see what is under them. Once you're done with repairs, you'll be REALLY glad you did it right.
