Post by SusieQ on Feb 12, 2015 13:20:56 GMT -8
It's a Shasta. My vent was 7" from the side.
RJ
Post by RJ on Feb 12, 2015 13:40:24 GMT -8
I'm listening. This was obviously a trouble spot on this trailer.
Post by SusieQ on Feb 12, 2015 13:51:13 GMT -8
Your old framing on yours is actually better than the earlier models. The actual vent frame was only connected to one rafter on one side on the older ones. The other three pieces were just fastened to the roof panel.
I did the 1/4" plywood crown and I ended up with a buckle, or a crinkly (looks like those new Shastas in one spot) in my roof at the curve, mostly my fault because I made it do something it didn't want to, not really sure the crown had anything to do with it, but the extra rafter I added might have.
RJ
Post by RJ on Feb 12, 2015 14:01:26 GMT -8
Wow, only attached to one rafter? Yikes. Don't suppose you have a pic of the plywood crown you put on yours so I have a visual on what Larry's referencing. I have an idea but a photo reference would help.
Post by SusieQ on Feb 12, 2015 14:06:49 GMT -8
I don't think I do, but Vikx has one here somewhere. I just cut 4 strips of plywood the size of my framing for the vent and nailed/stapled it on the framing boards. Then I took my electric sander and beveled the edges and corners a little so they wouldn't cut through the tin when it's stretched over it. Here's the one I did for my round solar vent on the other side in my closet.
Post by mobiltec on Feb 12, 2015 14:50:09 GMT -8
It is a piece of framing or plywood that raises the surface the vent sits on so that water doesn't puddle around the vent. If you watch my roof installation vids on the 57 Westerner it will show you how to avoid buckling by getting ahead of yourself with the stapling down and folding over of the metal around the vent area before you get there. Your vent is so close to the edge that I would only use 1/4 inch thick plywood... It's enough of a slope to shed water away from the vent.
RJ
Post by RJ on Feb 12, 2015 15:03:31 GMT -8
Got it, thanks folks. I'll rewatch the 57 Westerner roof install vids mobiltec. Oh, nice Kreg jigging on your solar vent SQ
Post by SusieQ on Feb 12, 2015 17:29:51 GMT -8
Thanks, RJ. I should have done two on each end but I think I screwed or nailed it from the other side, too. And my square vent looks like Mobil's pic.
RJ
Post by RJ on Feb 14, 2015 18:04:29 GMT -8
Post by vikx on Feb 14, 2015 22:21:02 GMT -8
Lookin Good RJ!
Sorry I missed the vent discussion. I agree, a little shim really helps.
Post by mobiltec on Feb 15, 2015 7:36:53 GMT -8
It's always a great feeling to get the lid back on. It gives you a feeling of light being seen at the end of the tunnel... Good job Rory.
RJ
Post by RJ on Feb 17, 2015 13:27:34 GMT -8
Post by vikx on Feb 19, 2015 22:44:30 GMT -8
Ooooo.... YUK.
RJ
Post by RJ on Feb 21, 2015 18:03:21 GMT -8
Checked fit on the new vent (gotta wait for the big brown truck to drop some supplies to finish the job), buttoned down Dot's top, and got busy on the curb side hatch and front skins. Got quite a bit done today. Tomorrow, gonna work on the final rear skin install and start cleaning up the skin edges and J rails (got a new wire wheel for my Makita grinder today I'm itching to try out). It's a good weekend Thanks for looking.
Post by SusieQ on Feb 21, 2015 18:59:36 GMT -8
Wow! Your progress is amazing.
