travelrn
Post by travelrn on Jul 19, 2014 14:02:47 GMT -8
Hi Everyone, I made the rash decision as many of us newbies do of going ahead and buying a trailer untested. I bought a 1964 shasta 20ft with rear gaucho bed and bathroom. Everything is original, nothing modified that I can tell. All original systems too. A couple water spots in the ceiling, so I am planning on ripping that apart. The ceiling paneling is some sparkly vinyl product. I will post pics soon of what I've got to work with. My plan is to work on it for 2-3 months before I take it out on the road and live in it, at least a couple months at a time. I'm a travel RN and am decently handy for a lady. I also want to update the electrical so I have more than a couple outlets, and install a cable connection somewhere appropriate. My question is should I just start dismantling all the seal strips and windows first, and then tackle the ceiling. It looks like I will have to remove cabinets to get at it all. The roof is rubbery looking as if roof coating was painted on. Should I try and remove it to the metal? Trying to avoid a complete tear down/off if possible. Larry's videos indicate to repair ceilings you have to go through the top, not from below. I just want to have a good plan to start off so I dont waste time futzing. I'm sure I'll have plenty of questions in the future but have been spending 1 hr + watching those awesome videos everyday. So hopefully not too many ! Thanks for all the great advice already here.
Post by vikx on Jul 19, 2014 21:27:33 GMT -8
Welcome! The rubbery stuff is probably roof coating of some sort and very nasty to work with/around. Most of the time, I remove all loose and peeling coating, especially at the seams and around all roof vents. Depending on the product, if you can re-seal the seams after stripping, along with the roof vents, it may be OK to leave the rest with a light coating. Unfortunately, the coating does not prevent leaks. Here's a link: vintagetrailertalk.freeforums.net/thread/1599/roof-seams-when-sealing-necessaryYour question is difficult to answer. Once the J rail comes off and the skins are lifted, repairs are necessary. Often the edge wood and cross boards/rafters show rot. The ceiling panels go on top of the walls, so that wood must be in good condition. None of these trailers are quick fixes.
purplepeep
One is never enough:)
1966 Serro ScottyTonga
Post by purplepeep on Jul 20, 2014 20:18:06 GMT -8
Hi and welcome!
Live with it and study him/her before you do anything. Take lots of pictures before you start and try to label everything as you go.
Get work clothes or overalls because you'll get pretty dirty.
Have fun and good luck!
travelrn
Post by travelrn on Aug 5, 2014 20:00:48 GMT -8
So I have managed to remove the roof skin in one piece (whew!) and am left with a 75% disintegrated ceiling that's a carpenter ant, water damage, chipmunk? nest (no mouse poop anywhere!) combo. I will probably replace the entirety. Wondering what everyone who doesn't have the birch interior uses for a ceiling replacement. I figure I can do that (it would look pretty) or go with something else. Any suggestions? I like the idea of the birch but have seen the white plastic type panels at HD, which could be easy maintenance and waterproofish. As far as beginning on the replacement of wall framing should I start from the bottom and go up or ? Making a laundry list of items to buy from VTS. Has anyone put the Fantastic Fan in the vent above the shower or just in the center of the trailer. I've got the 20ft version so a rear corner bathroom.
Post by vikx on Aug 5, 2014 20:58:35 GMT -8
I usually start at the skirt boards, using the bottom skin piece as a pattern. Sometimes you have to remove it, re-frame, and then tack the skin back on for the exact pattern.
The Fantastic should be in the middle. The bathroom door is often shut, so not as efficient cooling in there. You might consider a bathroom fan vent for the bath. Cheaper for one thing... Remember you'll need 12 volt wiring in that area.
Some sort of nice 3/16+ panel would be nice for your ceiling. They are structural, so it's important that the wall attachment is nice and secure.
travelrn
Post by travelrn on Aug 10, 2014 20:34:18 GMT -8
