Post by SusieQ on Nov 20, 2013 14:48:55 GMT -8
Humidity or the curing process could have had something to do with it. I'm just sorry it turned out like that for you. And thanks for sharing with us.
Post by mobiltec on Nov 20, 2013 14:54:01 GMT -8
Ok Shasta I couldn't find anywhere in the thread where it said all new birch when I read it. Still can't... But anyhow I used Minwax once a long time ago and had all kinds of problems with it so I had to do the entire job over and never went back to Minwax again.
61 Shasta
Post by 61 Shasta on Nov 20, 2013 15:53:44 GMT -8
Ok Shasta I couldn't find anywhere in the thread where it said all new birch when I read it. Still can't... But anyhow I used Minwax once a long time ago and had all kinds of problems with it so I had to do the entire job over and never went back to Minwax again. I am thinking this is the last time for me also, at least in this kind of an application. I have used lots of minwax on hardwood furniture I have built and have never had a problem. However, in most of those cases I have used a wipe on poly to finish them. By the way, the reference to the birch is in the first post about in the middle of the first paragraph.
Post by mobiltec on Nov 20, 2013 16:24:48 GMT -8
Geesh I finally found it LOL... Sorry about that. I was thinking of going with other types of finishes so I could spray but decided that was the easy way out and I have invested too much time into figuring out Shellac to give up now. And it really is easy to repair when needed. There are a number of places that get scratched on a regular basis. People wearing baseball caps with a button on the top will scratch the ceiling. Of course shoes will scratch all around the bottom and at the foot of the bed. Bringing things in and out will scratch that big cabinet next to the door. Hauling bicycles in your trailer will scratch everything. All this damage is easy to repair with Shellac.
Just my $0.15 worth. (Inflation you know)
Post by SusieQ on Nov 20, 2013 16:59:30 GMT -8
You can make your own wood putty by sanding an extra piece of birch into sawdust and mixing it with wood glue. In holes the size of a screw it ought to be almost invisible after some amber shellac. Cow, that's a most excellent idea! That's a luthier's trick. I always save the saw dust from my fretboards when I drill for the dot inserts then rub it in around them after I glue them in so there's no space. It might be more productive to drill large holes for the saw dust instead of sanding.
61 Shasta
Post by 61 Shasta on Nov 20, 2013 17:06:20 GMT -8
Just my $0.15 worth. (Inflation you know) I just got done spraying the icebox frame (in place) and hope I don't have to do any more spraying with all of the masking involved! Don't ask me why I didn't do this first instead of last because I really don't know what I was thinking!! When I put the first coat of poly on, I tried spraying it under the bunks to see how it would work. I didn't care for the job it did, too much worrying about runs and product thickness. I then went back to using the pads. That worked great for me. The more info I consume and the more I think about it, the more I am leaning toward the shellac answer. I really started this thread without a real thought of finding a solution, simply a way to educate others on my mistake so it don't get done again! Thanks for your 0.15 worth, all donations help.
Post by mobiltec on Nov 20, 2013 18:04:19 GMT -8
I believe we brought it up before in the old forum but there is also that French Polish job you can do with Shellac if you are REALLY into a mirror finish....
61 Shasta
Post by 61 Shasta on Nov 20, 2013 19:09:57 GMT -8
I'm not into the mirror finish, just like the semi gloss "feeling". I also think when you achieve a true semi gloss finish, it is easier to maintain. I would be interested though in reviewing the french polish process to see what it involves?
Post by mobiltec on Nov 20, 2013 19:21:09 GMT -8
61 Shasta
Post by 61 Shasta on Nov 20, 2013 19:42:26 GMT -8
Thanks Larry. I had looked at that blog in the old forum but did not go completely through it. I found the french polish section and I must say, I am impressed with what he went through to achieve his goal. Not for me but wow, what a craftsman. My hat is off. Thanks for passing along, perhaps this will keep it alive.
Post by cowcharge on Nov 21, 2013 7:14:03 GMT -8
I've mentioned tung oil a few times, both here and in the old forum, and never got any reaction so I guess it's not popular (probably due to the prevalence of people trying to recreate the old look), but you might want to consider it if you're not looking for a really glossy finish. It can be used over stain (even water-based, like my trim), but it gives unstained birch a beautiful golden tone, not orangey-amber like shellac (I'm not a fan of the orange-amber, or high gloss on walls or most furniture). The more coats you put on and the more you buff it, the glossier it gets, and it is sooooo easy, both to apply and repair. It gives such a nice warm glow without harsh reflections. Makes the grain look deep enough to stick your hands into it, and the grain varies with the angle of the light. It's really hard to do it justice with a photograph, but here's one of my bedroom wall, where it meets the back of the shower wall. Look how the flash reflected off the insulation (but not the frame) and lit up the birch. It still doesn't do it any justice, though. Tung-oiled birch in sunlight is absolutely gorgeous. And feels wonderful under your hand, too. For scuffs, you just sand or steel wool (if needed to smooth out a gouge or remove a stain), and re-oil the spot. It just blends right in.
This link is from a site that sells their own brand of pure tung oil, I include it only because it has some pics that really show the mild satiny glow you get. Check out the countertop at the top of the page and the drum kit farther down, and the floors. www.realmilkpaint.com/gallery-tungoil.htmlI used pure tung oil from the hardware store (not the above product), mixed 50/50 with mineral spirits to make it soak in. The "Tung Oil Finish" and "Danish Oil Finish" products you find at HD and elsewhere have some varnish mixed in, so they're not the same thing as pure tung oil. They may not have any actual tung oil at all. It's very similar to the French Polish process, but not as finicky. Sand the birch smooth with 400 grit (with the grain), blow or dust, then tack rag, brush on the oil/spirits mixture, let it soak in for half an hour to an hour, wipe off the excess, let dry to the touch (time depends on humidity, but it dries pretty slowly), hit with 0000 steel wool with the grain, tack rag, and repeat until the level of gloss is where you want it, then finally buff with a cloth. I can't say enough how really beautiful it looks, and how staggeringly easy it is. It comes out more like the wood paneling in the study of an old British house than a vintage camper finish. It isn't as waterproof as poly or shellac (you already fixed all the leaks so who cares, right?). More like water resistant, but it is oil after all, so water would have to sit on it to eventually soak through. It isn't as tough as poly, but since poly on thin soft plywood isn't much protection to begin with, and since it only takes a few minutes to repair scuffs, that is arguably a moot point. It also has the advantage of not trapping water behind the finish. It takes longer than shellacking or varnishing because of the slower drying between coats, but to me it's definitely worth it. I did mine outside on sawhorses, on a nice breezy summer day, and had no worries at all about what the wind might blow onto it, because I could just brush leaves, bugs or whatever right off with my hand or some air. And since a good finish isn't dependent on not being touched, you can lean the pieces up against any convenient wall instead of doing only one panel at a time or covering your shop with pieces of paneling, without the worry about messing up a half-dried finish. It's so EASY! With a bit of experimentation with stains, I know you could get the amber color of the old trailers too, if you wanted it. I wanted to keep it light and bright, so I didn't try that, and don't know what stain would work best or anything. Just another alternative, that I hope someone else tries some time.
61 Shasta
Post by 61 Shasta on Nov 21, 2013 8:44:34 GMT -8
Thanks for the post cowcharge. I have used pure tung oil on different small furniture things I have made for my grandkids and been extremely happy with the results. I have never given it the treatment you outline here but boy do like the look you have achieved. When I started on my shasta, I had "thought" I would go for a finished unit as close to original as possible including the amber "glow". As the resto went, things change, you take a liberty with one thing, like it and go on. When I got to the finish, as I have said before, I did a story board and chose the finish that gave me the results I was looking for. It gave off a soft semi gloss glow but not real shiny. The birch I bought was not cheap and had a really nice grain so I wanted to show that off. The ipswitch pine stain brought out the grain and with the top coat of polyurethane, I loved it. Now we are back to square one although the stain is still there even though I am stripping off the poly. In the next few days I will be looking at some of the options in this thread and make a decision of which way to go. Your input is appreciated. If nothing more, it certainly gives me another tool in my tool box of finishing methods.
Post by vikx on Nov 21, 2013 21:49:39 GMT -8
I've had trouble with Tung oil but not sure if it was pure or not... it stayed sticky. Is there a life on tung oil? I even wrote on the can that I didn't like the finish. Now I'm thinking it wasn't the correct product or poor application.
Post by schweetcruisers on Nov 22, 2013 7:21:56 GMT -8
I use Water based poly over oil based stain almost daily, it does not sound like a stain failure but a poly failure. You mention that Minwax is the manufacture of the Stain but what brand was the Poly? I know it is impossible to know this before you but the product, but water based anything(glue, stain, putty, poly, etc..) can't freeze, if it froze before you bought the product, it could have been predetermined to fail.
61 Shasta
Post by 61 Shasta on Nov 22, 2013 18:32:19 GMT -8
After much agonizing and considerable elbow grease I think I know what happened. Here is my "theory". Please feel free to poke holes in or expand on it as you see fit. Short history first: Temperatures in the shop at the time was above 70. The birch I started with was new off the shelf stuff. Clear and unspoiled. Once it was all installed, I lightly sanded it to remove any slivers etc. I then wiped down thoroughly with tack cloth's. Applied a light coat of minwax ipswitch pine stain, by sections. After leaving on a few minutes, I wiped it down with a soft cloth to remove whatever hadn't penetrated. I changed cloths as necessary. After completing the whole interior, I let it stand for about a week before beginning the poly application. Before applying the poly I again wiped it down with a tack cloth to make sure it was dust free. I did notice that the tack cloth has some light brown tint in some area's but nothing was sticky or loose. After wiping down a section, I applied the first coat of polyurethane. I continued this process until I had completed the whole unit. I might add that the side cupboards and benches were done outside the trailer before installation so they weren't completed at his time. Even so, they also have the same problem. My theory: When you wipe down a regular piece of wood after staining, if there is any material left in the pores of the wood they will either continue to penetrate and evaporate until the surface is dry. This birch veneer has a very thin (less that paper) actual birch skin. Under this as near as I can tell is a substrate of non porous material. I did wipe it down with a soft cloth to remove any stain residue, however, I don't think I wiped it down enough. Because the veneer is so thin, if there is ANY stain residue left it has nowhere to go except sit there. I did let it dry and it felt smooth and dry to the touch, however, I THINK there was partially dry material in the pores and when I applied the poly the moisture from that released this residue and created non stick surface. I suspect if I had wiped it down then went over it with a lightly dampened paint thinner cloth all would have been good. I am running some test boards right now to test out this "theory". The first one I did was with an oil based poly and the next one is with the water based stuff. The one I did with the oil based poly did the trick so now we will see how the water based test comes out. So far I have stripped the poly off of about 1/3 of the trailer and will not go any further until I see how these tests come out. This first 1/3 includes the all of the front cabinets and back to the area around the closet along with the associated roof area. I'll post pictures before and after when I decide what comes next.
