flyte 1959
1959 shasta airflyte
Post by flyte 1959 on Oct 21, 2013 15:16:19 GMT -8
I am looking for 1/8 4x8 birch plywood in alabama or the southeast. thanks
Post by mobiltec on Oct 21, 2013 16:14:40 GMT -8
Call every single lumber company within a 300 mile radius and someone will either have it or be able to order it. (usually)
Post by kto17 on Oct 21, 2013 16:43:35 GMT -8
Just an FYI. 1/8" birch used in these trailers is not the same as what is called bender board. Bender board is more expensive.
maddan
57 Westerner
Post by maddan on Oct 21, 2013 19:23:05 GMT -8
I have a follow-up question on 1/8" birch. I'm doing a complete replacement of all the paneling in my 57 Westerner. Top skin is now removed. Any concern with using 1/4" birch on the side walls, and 1/8" on the ceiling, front and rear? 1/4" is more readily available, maybe even cheaper, plus it might hold up better to wear and tear.
Post by mobiltec on Oct 21, 2013 20:29:27 GMT -8
That's fine.. Lots of people do that and some of the manufacturers did it. I see no problem with it. Your cabinets will set out a bit more so don't try to use the same screw holes into the floor. Make new ones in the cabinet.
Post by SusieQ on Nov 13, 2013 14:39:39 GMT -8
I'm on the search for 1/8" large enough to replace the panel under my back window. Even online, the largest piece I can find is 30" x 48". Our Lowe's has 1/4" but I don't want to replace the entire back wall. Since I can't find it in 4'x 8' sheets, can I use two pieces in the back with a seam down the middle under the window?
Post by mobiltec on Nov 15, 2013 16:25:55 GMT -8
Ya why not? Try to keep the seem away from the curve. Keep it in the flat part.
Post by SusieQ on Nov 15, 2013 18:49:44 GMT -8
Good news, I found some 1/8" birch 4'x8', bad news it requires a $350 order (I can wait until someone else orders from that supplier, like I'm gonna' wait that long) and more bad news, it's $65 a sheet.
Not happening. I'm just going to redo the entire back with 1/4".
Aloha!
1964 Shasta 1500
Post by Aloha! on Nov 20, 2013 7:42:21 GMT -8
Maybe share the cost with someone else that needs it? I would offer but I believe my Handy-Andy has already gone ahead and replaced the necessary pieces with /14". <sigh>
Post by SusieQ on Nov 20, 2013 7:55:03 GMT -8
Aloha, I've bought 1/4" from Lowe's and picked out some really nice looking sheets. Yes, we pulled out about a dozen or more before I found what suited me. I'll be replacing most of my plywood, anyway much to my surprise.
I don't really want to pay $65 a sheet for it. My $$$ is adding up quickly. But Better Living is where I went and they get it from a supplier in Richmond. I haven't searched Richmond. If the 1/4" doesn't suit me, I'll go on another hunt.
Post by cowcharge on Nov 20, 2013 14:56:03 GMT -8
I have a follow-up question on 1/8" birch. I'm doing a complete replacement of all the paneling in my 57 Westerner. Top skin is now removed. Any concern with using 1/4" birch on the side walls, and 1/8" on the ceiling, front and rear? 1/4" is more readily available, maybe even cheaper, plus it might hold up better to wear and tear. I did that in my (roomy) 2250, and the lost quarter of an inch in every direction isn't noticeable. It's gotta be a lot stronger too.
jannica
Post by jannica on Jan 24, 2014 15:08:14 GMT -8
Do you guys think it is possible to glue/nail 1/8" birch paneling on top of my cabinet faces, closet, and shelves? I am worried that I'll never get the wood to look pretty otherwise and I don't really want to build everything from scratch. I was thinking I could cover the outside and shellac that wood instead. Then it would at least match my new paneling on the ceiling and walls. I know it would increase the thickness, but I think it might work otherwise, except maybe around the frame of the cabinets which I'll just have to sand and hope it looks ok. Thoughts?
Post by mobiltec on Jan 24, 2014 17:03:29 GMT -8
Yes it's done all the time. Buy a whole bunch of little clamps and then apply new birch paneling to the faces using wood glue and a whole lot of clamps all the way around the edges. Spread the glue with a throw away paint brush. Might want to thin the glue down with water just a tad. Then once the glue dries remove the clamps and take your mouse sander to the edges to round them off at a little angle and go for the shellac.
You can buy bags of plastic clamps at HD for cheap.
jannica
Post by jannica on Jan 24, 2014 17:09:37 GMT -8
Thanks! Yes, I have some of those little clamps from HD. I will have to buy a few more for this project though.
Post by mobiltec on Jan 24, 2014 17:14:29 GMT -8
You can do one or two faces per day/evening... That's the kind of work I like to do in the house in my spare time while watching a game. Remember to always cut your paneling from the back side to avoid splintering of the good side edges.
