Post by Ten on Dec 8, 2016 20:16:57 GMT -8
It's easier to let the trailer find you rather than going out and finding them. It is usually when you really aren't looking. I finally got the Avalon home, and no more than JUST started to clean it out and get it set in its spot, when another found me. It was advertised as a "project Shasta"...and boy is it ever! It was only 10 miles from home, how could I say no? The date on the sink is August of 1958. It had "donor" written all over it. It was parked on a private lot and family owned, last registered in 1974. It had been storing piles of treasures... you know, mostly garbage. I took my spare wheels and jack, and my magnetic light kit, and brought it home anyway. It was parked there with color-matched wheels and the hubcaps. Even came with its own bird nest. The stove and refrigerator are missing, as is the electric inlet for the 110-V service. Just as well by the looks of the old fuse block. The sink cabinet is trashed, but the sink is there. It also appears that the tongue is bent upwards, and the coupler is not quite straight either. I am still cleaning it out, along with working on the Avalon. I should have some more photos and a little better idea of its condition as I go. So far, I am encouraged by some of the points I've found.
Post by SusieQ on Dec 8, 2016 21:23:18 GMT -8
You definitely got a fixer upper there! Way to go, TEN! Another man's trash... your treasure!
Post by vikx on Dec 8, 2016 21:23:45 GMT -8
Surely, you will find hidden treasure in there... The back ceiling isn't too bad! Congrats.
Post by mrmarty51 on Dec 8, 2016 23:14:23 GMT -8
Yeah, I too noticed the ceiling pic. I also noticed that under the front window there is not hardly and staining from frost, condensation or moisture. I surly would love to come upon such a nice example to be able to add another camper to the one I already have, i could then have the beginning of a fleet. LOL
Post by mel on Dec 9, 2016 4:40:13 GMT -8
Love it! Can't wait to see more pics
Post by nccamper on Dec 9, 2016 4:47:37 GMT -8
really great. A major score.
jeremiah
Post by jeremiah on Dec 9, 2016 6:52:01 GMT -8
Nice project . I would give it a shot to bring it back myself . I will place a wanted ad in the spring ...
Post by Ten on Dec 9, 2016 15:43:47 GMT -8
I put the original wheels back on for a photo op. And a couple impressive interior photos: One of the better vents that I have seen on something this old. Found this: At some point someone must have had to deal with critters, and did me a huge favor. There are some of the cabinet fronts and drawers missing, but the ones that are here are turned upside down!
Post by mel on Dec 9, 2016 16:20:49 GMT -8
It looks like its in pretty decent condition for it age. awesome find Now a compact needs to find you to round out your collection
Vintagehotdog
Hi, we are Paul and Irvina, Currently rebuilding a 12' 1958 Easy Traveler
1962 Oasis 18'
Post by Vintagehotdog on Dec 9, 2016 16:33:26 GMT -8
Another great trailer. Looks like you may be buying more carports soon!
Post by nccamper on Dec 9, 2016 19:13:46 GMT -8
I really like this one. Messy enough to be cheap yet preserved enough to save. Nice.
Keep this up and "TEN" will refer to how many campers you own.
Post by mrmarty51 on Dec 9, 2016 21:10:36 GMT -8
That ceiling vent looks to be the exact same type of vent that is in My camper. I knew I had a problem when, cranking the wing nuts, the vent would flex about four inches upwards.LOL
Post by Hamlet on Dec 10, 2016 8:00:40 GMT -8
I love it. Pits fun to see something this size still managing to keep a ham-ish shape. I think Hamlet ends right about where the axle is on this one. Congrats!
Post by Ten on Dec 10, 2016 15:32:10 GMT -8
Thank you all for the well-wishing and all. I really had no intention of keeping this trailer, but the more I dig, the more intrigued I get with it, and the more impressed with the condition. Although I should start a new thread just to make the references for the particular trailer easier to find for anyone searching, here are a few more photos today. Went to work finding the VIN number today. It is still barely legible on the tongue, and is going to require some more careful digging to make it show up in a photo for the DMV. The tongue seems bent upward and slightly twisted one side, but the damage does not seem so bad that it would be difficult (for a qualified welder) to fix. The coupler seems a little off too, but I am not sure of how these looked to start with. We had them off before the photos, but the chain lift brackets for the weight-distribution bars were twisted also. The streetside has a crease in the skin, which had a patch job done on it. It was taken loose from the bottom of the skirt boards, and had one small hole in it. It looks like a quick hit of bondo or something similar, quite a long time ago. The black water tank is on the same side and looks like it was pushed in by being impacted from the bottom. It was a metal tank and is perforated by rust now. My son speculated that maybe it suffered a blown tire, and twisted agaiinst teh hitch when it blew, in order to twist in this manner. It is interesting to see the old wastewater setup. The fittings were quite different from the later models, but the setup was similar-- the grey water bypassed any holding , and the blackwater tank was held by a gate valve. Aside from the obvious weight advantage of replacing the metal tank and iron piping with PVC, there is also a matter of not ending up with missing portions... Also got the access door open for the water heater today. I was never aware of what Shasta used in these early models. Strangest looking thing I have seen in quite a while.... A quick search finds that the company that manufactured these in the '50-s is still around today in Germany, has been around since 1874, and is still producing water heaters and boilers, but does not export anything including parts to the US. A modern replacement may be in order, if indeed this ole gal refuses to come out of retirement. Oh yeah, and I finally remembered to get a shot of the sink date stamp:
Post by mobiltec on Dec 10, 2016 16:05:34 GMT -8
Turning the drawers upside down for storage is a great idea... I think that's a Keeper Ten.
