txoil
1960 Shasta Deluxe 19
Post by txoil on Sept 22, 2014 17:00:48 GMT -8
So we have planned for months to make a rally in October at Fentress, Tx...reserved the site etc,etc. However there is a slight problem. Sometime this summer, a leak occurred in Tallulah Belle, and the fiberglas insulation above the front window became wet. Which caused the birch above the window to wrinkle and disintegrate, and also caused the birch below the window to stain, as well as the curbside dinette panel. Since I work offshore on a 14/14 schedule, my time to work on the trailer is limited. Having said all this, we started on an emergency facelift last Thurdsay. Removed entire front end, dinette wall and roof (in order to install new one piece roof. Also replacing a broken glass pane in the streetyside dinette window frame and fix up some random issues in order to get her 'rally ready'. Holy Smokes! Since Thursday we have built an entirely new front end, insulated and reinstalled paneling, electric, propane and cabinets... it has been a month's worth of work condensed into 5 days. Really amazing how much rot had occurred in the NEW WOOD I had installed just last September. We have no idea whence the leak happened, but it laid waste to everything it touched. Pics will follow but I am just too tired right now to do the Photobucket thing. I pray this does NOT happen to any of you!
Post by SusieQ on Sept 22, 2014 17:45:49 GMT -8
So sorry that happened! Sounds like you've done an amazing job with your emergency facelift.
Post by mobiltec on Sept 22, 2014 19:21:56 GMT -8
Leaks happen. Sounds like a J Rail leak. I suppose it could be a seam... I really like using Gutter Seal to top off the putty tape under the J Rail. That really finishes off the seal. Nothing is getting through.
Post by vikx on Sept 22, 2014 21:36:37 GMT -8
OH Man, so very sorry... Nothing like a leak to make rot. Glad you got her fixed. Looking for pix.
59shastadeluxe
'59 Shasta Deluxe
Post by 59shastadeluxe on Sept 23, 2014 6:06:45 GMT -8
That bites!
txoil
Post by txoil on Sept 23, 2014 13:54:02 GMT -8
Friday, sept 19. Front end removed, starting on replacing. Different view of Tallulah Belle sans front end. Saturday Sept 20. New dinette wall and new front lower panel cut, framed shellac'ed and in place. Saturday Sept 20 front view. Monday morning, Sept 22 (Our ten year anniversary, ironically enough) New front curve in place and cabinet reinstalled, gas and electric connected. Monday evening, front skins on and entrance door being reinstalled. Today I cut and installed a new roof, sprayed etch primer and will spray white base coat this evening. Lots of work for five days!
Post by vikx on Sept 23, 2014 21:36:18 GMT -8
WOW. Great work.
Post by cowcharge on Sept 24, 2014 5:42:45 GMT -8
Did you have any trouble with the paint cracking when you messed with the skin edges?
CorvettCrzy
'58 Corvette, '64 Franklin
Post by CorvettCrzy on Sept 24, 2014 6:27:26 GMT -8
Wow, Incredible!! A Month's work in 5 days................... on our timeline that's "A Year's work in 5 days". Looks beautiful, you can show her off proudly at the rally!!
txoil
Post by txoil on Sept 24, 2014 14:27:35 GMT -8
Got the new roof primered and painted, front edge trim 1n place, rock guard re-installed. Now when I come in from offshore I will have 48 hrs to complete all the little tasks before time to head for the rally. Are we crazy for this obsession of ours? I have lost 10 lbs. this week with all the heat and humidity.
txoil
Post by txoil on Sept 24, 2014 14:30:17 GMT -8
Did you have any trouble with the paint cracking when you messed with the skin edges? Not cracking, but discoloration from butyl putty and weather. I will touch up the noticible areas to at least make them blend in. This camper is for us to use, so I am not worried about normal wear and tear. After all isn't that what winters are for...to repair the boo-boos on our vintage beauties?
Post by vikx on Sept 24, 2014 21:30:07 GMT -8
Congrats on losing the 10 pounds!
Post by Teachndad on Sept 25, 2014 5:51:54 GMT -8
Leaks happen. Sounds like a J Rail leak. I suppose it could be a seam... I really like using Gutter Seal to top off the putty tape under the J Rail. That really finishes off the seal. Nothing is getting through. Excuse my momentary threadjack. When looking at a used trailer, is there a way to tell if the gutter seal was used over the J rail vs. silicone? As a newbie searching to buy a vintage trailer how would I tell the difference to see if it was done right? I read threads like this and I continue to be amazed at the craft of trailer restoration. Enjoy the rally! Rod
swirlygirls
Post by swirlygirls on Sept 25, 2014 9:37:04 GMT -8
I'm so sorry to hear about the leak. As Gilda Radner said, "it's always something." I an't imagine how much work you've done. Wow.
Post by mobiltec on Sept 25, 2014 18:35:35 GMT -8
Leaks happen. Sounds like a J Rail leak. I suppose it could be a seam... I really like using Gutter Seal to top off the putty tape under the J Rail. That really finishes off the seal. Nothing is getting through. Excuse my momentary threadjack. When looking at a used trailer, is there a way to tell if the gutter seal was used over the J rail vs. silicone? As a newbie searching to buy a vintage trailer how would I tell the difference to see if it was done right? I read threads like this and I continue to be amazed at the craft of trailer restoration. Enjoy the rally! Rod Never really had to check. You can't tell the gutter seal is there. It just looks like a REALLY good putty job or it's painted and you see nothing till you go to pull the J rail although I don't see why you would want to if it had gutter seal. If it's Silicone it will be hard to remove without "Re-Mov" silicone remover. I learned about the gutter seal from Vikx....
