Post by mobiltec on Mar 24, 2024 16:05:22 GMT -8
Everyone is getting busy. Mandi I will be bringing a large jack with me so don't worry about it until I get there.
mmh
Post by mmh on Mar 27, 2024 10:27:27 GMT -8
low-lincoln
1967 Field & Stream
Post by low-lincoln on Mar 28, 2024 10:03:35 GMT -8
Here's the Field and Stream at Buellton 2023. Waiting for the rain to stop to get back on it! Already signed up for Buellton 2024. Thanks for getting the Community back together" Jeff
Post by Teachndad on Mar 29, 2024 5:22:17 GMT -8
Hey Mandi,
What grit did you use for sanding? Did you just hand sand with a sanding block? Did you consider using denatured alchohol to remove the old shellac or just sand away?
I have two trailers. One a 1963, and that the shellac is flaking off in most of the trailer. You can rub your hand along the surface and it just comes off like a powder. In another trailer from the late 50s, the shellac is not flaking.
What was the surface like on your surfaces before you started sanding?
thanks
Post by vikx on Mar 29, 2024 11:40:04 GMT -8
We scraped the flakey shellac with a plane blade, then sanded. I learned the hard way that any white or light spots showed badly thru clear shellac. (57 Deluxe) With amber, they are well hidden.
Post by mobiltec on Mar 30, 2024 7:27:34 GMT -8
Yep. The scraper is the way to go first. Then sand. Anything left in the grains you will be able to see with shellac.
mmh
Post by mmh on Apr 1, 2024 15:50:08 GMT -8
We scraped the flakey shellac with a plane blade, then sanded. I learned the hard way that any white or light spots showed badly thru clear shellac. (57 Deluxe) With amber, they are well hidden. I used 80 grit. It was painted so I had that to get off. I didn't know(/remember) Larry's rec for a scraper. I'll be doing that next time. Everything in there was painted except the inside of the various doors and cabinet's. I'm going to sand those down and Tung oil polish them. The paint scheme that the PO's did was really lovely, so I'll be going with that again although I'll actually clear shellac them so they don't scuff in 30 seconds again. Their sealing and damage repairs, however, were... not lovely.
Post by mobiltec on Apr 4, 2024 10:20:15 GMT -8
Oops... I did it again.... How many people get to do two of these? Yep. I just bought this as a birthday present to myself. It's a 1948 Mainline Silver Lark. It's the little brother of the Silver Lodger that I did. This one is a 14 footer. Other than being a bit shorter, it's pretty much the same as the other one. I'll be picking it up next week.
Post by vikx on Apr 4, 2024 13:20:01 GMT -8
Great Reward for all your hard work. Congrats!
mmh
Post by mmh on Apr 9, 2024 15:20:22 GMT -8
Plywood linkIn case anyone needs some of the good stuff, Home Depot has the sanded plywood HALF off today.
Post by mobiltec on Apr 12, 2024 17:10:00 GMT -8
Plywood linkIn case anyone needs some of the good stuff, Home Depot has the sanded plywood HALF off today. Dang. Now that's ridiculous...
Post by mobiltec on Apr 18, 2024 18:55:19 GMT -8
Just returned with the 48 Mainline Silver Lark in tow. She towed like a dream She's in pretty good condition too. I want to camp in this trailer a few times this summer before I start the restore hopefully at the end of this Fall. Photos to come.
low-lincoln
1967 Field & Stream
Post by low-lincoln on Apr 19, 2024 12:47:06 GMT -8
Just returned with the 48 Mainline Silver Lark in tow. She towed like a dream She's in pretty good condition too. I want to camp in this trailer a few times this summer before I start the restore hopefully at the end of this Fall. Photos to come. Glad you both made it back safely!
mmh
Post by mmh on Apr 19, 2024 15:59:08 GMT -8
Just returned with the 48 Mainline Silver Lark in tow. She towed like a dream She's in pretty good condition too. I want to camp in this trailer a few times this summer before I start the restore hopefully at the end of this Fall. Photos to come. Awesome!
barb
Post by barb on May 3, 2024 11:40:52 GMT -8
