Post by vintagetina on Aug 2, 2023 12:22:54 GMT -8
Hello I bought a 1966 Shasta Compact and I will be mostly traveling over the rocky mountains for camping with 110km/hr speed limits and thus would like to possibly flip axle and increase the wheel and tire size to 15inch. I am wondering if anyone has done this and the process. I was hoping to purchase a 5 bolt stub axle from princess auto if that is compactible with the bearings or replace the entire axle
Post by nccamper on Aug 3, 2023 3:49:03 GMT -8
Welcome!
i’m no expert, but flipping the axle on a vintage campers changes the center of gravity. I wouldn’t recommend doing it. others may disagree.
Post by Teachndad on Aug 3, 2023 4:24:13 GMT -8
Post by vikx on Aug 3, 2023 12:08:00 GMT -8
If the axle is mounted above the springs, it can be moved below the springs without changing the camber... There are also blocks made to lift modern trailers; talk to a frame and axle shop.
