Post by tpcm5000 on Apr 24, 2023 6:18:11 GMT -8
Hi All,
Question on pex to fixtures so adding to this thread.
I have my water tank and new pex pipes with crimp clamps installed, yippee!
Untitled by Tom Myers, on Flickr
I planned on using sharkbites to connect my 1/2" pex to 1/4" copper. I clipped the copper about 1' from the shower and sink fixtures. I was optimistic as the copper looked in good shape, but as has been shared, it has expanded and is no longer perfectly cylindrical so I cannot get the Sharkbites on the copper (they of course slip on the pex easily).
For the shower, I have a flare tool, so thinking I can go get 4' feet of brand new copper, flare, and pretty certain the sharkbites will slip on with ease.
Shower front:
Shower back:
Copper stem I will flare and replace with new copper:
For the sink, where I first tried to use the sharbite, it did not slip on all the way, so I tried to pull off and pulled the copper completely out of the fixture (to my surprise). I would have thought there was a fitting between the the copper and the fixture, to hold it in place, but it looks like the copper lines for the sink are simply inserted into the bottom of the hot/cold faucet handles (with some sealant at the opening).
Sink top:
Sink bottom:
So two questions, the big one, what is going on with the sink, is that all there is to the connection between the copper pipe and faucet handles? Can I take the same approach, simply insert the new copper pip
e I purchase and maybe add some sealant? Or is there a fitting somewhere in the handle I need to utilize?
And overall, I know sharbites get mixed reviews, but with new pex and copper pipes (the stems I create), and considering I will have access to the sharkbites to inspect and monitor, any thoughts on my plan or if I need to consider alternatives? Another advantage of the sharbites are I can use in tight spaces, no way I could operate a crimping tool under the sink, Vik is right, you need to be a pretzel, ha!
Thanks!
PS for others looking at pex and options, this is a really helpful discussion: vintagetrailertalk.freeforums.net/thread/653/copper-plastic-flexible?page=1
Shower front:
Shower back:
Sink top:
Sink bottom:
Thanks!
