Post by nccamper on Dec 8, 2021 5:38:22 GMT -8
I wish my cabinets were in the same condition. I'm not sure if they can be saved. Even getting the old and new wood to match may be impossible.
Post by mobiltec on Dec 8, 2021 6:58:40 GMT -8
I wish my cabinets were in the same condition. I'm not sure if they can be saved. Even getting the old and new wood to match may be impossible. Never Give Up...
aslmx
Post by aslmx on Dec 8, 2021 12:00:28 GMT -8
I wish my cabinets were in the same condition. I'm not sure if they can be saved. Even getting the old and new wood to match may be impossible. Never Give Up... Thanks for all you do Larry. I’ll get burnt out and then I’ll binge watch your videos to get reinspired. I’ve watched your front window install for the Shasta 50 times and I still need to go back a couple more times to make sure I get it right.
aslmx
Post by aslmx on Dec 8, 2021 12:03:38 GMT -8
I wish my cabinets were in the same condition. I'm not sure if they can be saved. Even getting the old and new wood to match may be impossible. I’m going to do my best to save the frames. A man once said if you replace everything it’s a rebuild instead of a restore. My finish might not match perfect but I’ll do my best. I still have to come get some of that plywood though. They’re not open on Saturday and close early on Friday. I asked him if he would ship and he said “ sure, send me a truck and I’ll throw it right in there for you”. Lol
shastatom
Shasta 54,57 1500 58 Airflyte
Post by shastatom on Dec 8, 2021 18:28:02 GMT -8
cabinets look good. Keep going. You have another camper to get done.
aslmx
Post by aslmx on Dec 8, 2021 19:40:54 GMT -8
cabinets look good. Keep going. You have another camper to get done. yep she’s wrapped up for the winter. Ill go out and just stand and look in it every few days. Can’t wait to get started on it. Do you still have a yard full of shastas
shastatom
Post by shastatom on Dec 9, 2021 15:27:14 GMT -8
put 2 away for the winter and one is in the garage
aslmx
Post by aslmx on Dec 16, 2021 18:02:22 GMT -8
Hit a huge milestone. I got to sniffing around on the facegram and I found a guy with 16 sheets of 1/8" birch. Made a 2 hour ride lastnight and came home with it at $18 a sheet. IMG_2537 by will andrews, on Flickr
Andy Smith
1955 Aljoa Model 16 Sportsman
Post by Andy Smith on Dec 17, 2021 7:45:19 GMT -8
Nice score!
idaho211
Post by idaho211 on Dec 17, 2021 19:19:33 GMT -8
Good find. Nice to have the right materials.
preacher
We have finished the restoration/remodel of our '68 Frolic. We hope to see you on the road.
Post by preacher on Jan 2, 2022 18:32:04 GMT -8
Thanks.
Post by Teachndad on Jan 4, 2022 5:19:55 GMT -8
Hi Friends,
I have been reviewing this thread. I don't think anyone has ever asked this, but how did you get the axle off the trailer and then rest the frame with body attached onto the ground? Did you take any pix of the process?
Cheers,
shastatom
Post by shastatom on Jan 4, 2022 17:36:40 GMT -8
If the tongue jack is still on you do it this way, Put the trailer on jack stands. remove the axle, lower the trailer down to the lowest setting of the jack stands, raise the tongue jack to touch the ground and I then normally come from the back side and jack up the the trailer on one side and lower pull out the stand and lower that rear corner to the ground. I then go to the other side and other side and do the same thing. (I do have a low profile jack)I now go back to the front and rise the camper with the tongue jack and pull the jack stands and then lower the camper to the ground with the tongue jack.
Now if you don't have a tongue jack you need to do much of the same thing but I then use the jack under the tongue and lower it until I can't go any further and then I use a large pry bar and a chunk of wood to get it off the jack.
Post by Teachndad on Jan 5, 2022 6:46:22 GMT -8
Thanks Tom. Did the rear corners of the skins and bumper come through unscathed? If you remember, can you take a few pix of the process to raise the trailer when you get to that point? I may have to do this with my Westerner because of space constraints.
Cheers,
shastatom
Post by shastatom on Jan 5, 2022 18:42:50 GMT -8
I will try and remember. Everything seemed to come out just fine but you putting it on the bottom of the frame so you do create a little but a paint scuff on those spots unless you can put it down on wood but I didn't have the room to even have wood under so it went right down on the angle iron and frame.
