jbenini
1976 RL-1750
Post by jbenini on Nov 4, 2017 16:10:28 GMT -8
Hey all, spent several hours working on getting the 12v side of my Shasta functional this afternoon. Got a good battery, untangled the wiring, got it hooked up, and now all the interior lights light up and the range hood fan and light work on battery power. Then I plugged in the converter, and it's still buzzing like it did before I got a battery. So, I check the voltage going to the battery, 13.5 volts, so the charging side of the converter is working...then I checked the voltage at circuits 1-3 and I've only got 6 volts. AND, the buzzing stops if I turn on a light. Wondering of one of the diodes went bad, if the buzzing is caused by a loose plate in the transformer, maybe someone else has had this problem and knows what it is? I'm thinking about disconnecting the three 12v supply wires one at a time and see if the buzzing stops, but the fuses are all good and with the converter unplugged and everything turned off, my meter doesn't show any current drain so I don't think there is a short anywhere. Bad ground, maybe? let me know what you think, thanks.
Post by vikx on Nov 4, 2017 20:42:26 GMT -8
A lot of old converters hum or buzz. Just the nature of the brute. You can take them out and work on them, depending on brand and accessibility of the innards. The older ones are easier than newer...
If it's a Magnatek 6300, they are well known for being noisy. You can replace the converter portion with a Progressive Dynamics unit; they make them to fit in the lower portion.
And when in doubt: GROUND IT AGAIN.
