poodlecamper
Post by poodlecamper on Oct 16, 2017 9:40:41 GMT -8
1968 Shasta Compact 110 original rear wall light was working,then just stopped. Would appreciate any help on where to follow wiring to repair if possible. Street side, about 12" above bunk
Post by vikx on Oct 16, 2017 19:47:34 GMT -8
First, be sure everything else is working. (outlets, other lights) Try a new bulb in the light. If that doesn't work:
Take it off the wall and inspect and test the wiring. Test the switch on the light. I'm thinking it's the switch or a loose connection. Any hardware store should be able to help you find a replacement switch.
