Post by mel on Sept 5, 2017 9:11:10 GMT -8
Has anyone had any issues with their hand pump leaking all over the counter?? I pump it like normal it works fine, then two hours later there is water all over the counter. It seems to be leaking where pump handle meets the base above the counter.
Post by vikx on Sept 5, 2017 20:46:02 GMT -8
There might be an O ring that has failed. Google Rocket hand pump and look at the breakdown. Repair kits are available. Be sure it isn't cracked before ordering the kit.
Post by danrhodes on Sept 5, 2017 20:57:01 GMT -8
You can also get assorted o-rings at home Depot. I was able to match the one in my pump. Install with a little silicone plumbers grease to keep it smooth.
