Post by cowcharge on Nov 3, 2013 18:54:34 GMT -8
Mine's only 37 years old, but the furnace has a cast-iron burner in it that's as heavy as an exhaust manifold, and it had only a couple of tablespoons of rust and soot in it... I only had to clean the mouse nest out of the fan, adjust the sail switch, squirt a little oil on the motor bearings, tweak the burner air adjustment, and it works like a charm, even the original mechanical wall thermostat and the magic sparky thing work... Of course my furnace doesn't look like yours, your mileage may vary. But hey, if it works, original is better, right? Back when they designed things to be REPAIRED instead of thrown in the dump? When manuals had exploded drawings and part numbers for everything?
Yes, I know it's a piezoelectric igniter, but it's more fun to type magic sparky thing.
corky
1964 Shasta 16-SCS
Post by corky on Nov 3, 2013 19:41:50 GMT -8
Thanks cowcharge! 37 is way younger than 50, but if I can figure out how to pull the covers on this heater, I'm game for checking it out. Today I spent a little while letting the grandsons get in some cleaning, while I looked at other things. They had a blast with the initial cleaning, but things turned into a water-battle when they caught me taking pictures instead of working with them! LOL   I removed the dual LP tanks and they were both full--hadn't lost anything over the last 8 years! Also checked out the condition of the wood frame along the bottom edge of the metal, and in the wheel wells...it's rotted completely away. Starting to look like this canned ham is gonna need peeling to make structurally-sound...we'll see! Nite, Corky
Post by cowcharge on Nov 8, 2013 9:45:49 GMT -8
You'll probably need to either buy new propane tanks, or if they're still in good shape, get Overfill Protection Device (OPD) valves put in, in order to get them filled in the future. Maybe the PO had them done? Check the tops of the tanks for a certification. Old tanks with new, legal valves and an inspection are only good for five years. Mine had the old left hand threads, I had to specify those when I had the new valves put in. 'Bout $75 for the inspection, valves and certifications at Maine Oxy, an industrial gas seller.
Post by bigbill on Nov 8, 2013 11:58:14 GMT -8
I had my tanks re certified and new valves installed to meet current standards at the local propane supplier for ten dollars a tank. Dropped them off and came back in a couple of days to pick them up and the only additional charge was for the propane to fill them.
Post by SusieQ on Nov 8, 2013 20:10:55 GMT -8
Great looking boys! I love the overalls! Looks like they had fun. You definitely have a gem in the rough.
Btw, that story of how you got Ms. Belle is a tear jerker.
corky
1964 Shasta 16-SCS
Post by corky on Nov 25, 2013 14:02:22 GMT -8
Hey again folks, With my last few posts, I promised to start showing more detail on some of the issues we'll be dealing with to get Ms. Belle back on the open road, so here goes. It ain't pretty, but also not surprising for a 49-year-old beauty that's been stored outside for the last 8 years. These first two shots show that Ms. Belle's roof is pieced together from multiple pieces of metal, which means at least four seams up top. I guess that means four different opportunities for leaking, not even counting the openings for the for the roof vent, furnace flue, and plumbing vent pipe. But from closer inspection that may not be evident here, it appears that the roof is partially collapsed to the rear of the roof vent. You can see plentiful amounts of roof tar added around the plumping vent pipe and furnace flue, as well as along the seam from the furnace flue to the port/street side of the roof. Is there a source for a single piece of metal to replace these?   After parking Ms. Belle in my driveway and placing her on jackstands, I noticed that there were several pieces of a fairly large (2-in diameter) branch scattered around, which might have been the source of the collapse. There is significant ceiling damage from the roof vent towards the entry door, and over the bathroom...   ...which looks really bad from inside the bath over the shower where the plumbing vent pipe exits...  There is also damage on the street side ceiling forward of the closet; and while it looks less dramatic than the others, must still be dealt with as well.  Ever mindful of the need to stay positive as I inventory what must be done, I'll note the good news: Ms. Belle does seem to have almost all of her original parts, including the shower curtain rail, all but two of her original light globes, and 99-44/100ths of her original charm! The only things missing are the original fridge, the magazine rack, two light globes, one jalosie window crank, and the snake which left its skin at some point in the past (Yippie...I won't be looking to replace that!) My two grand sons have already asked when we'll take Ms. Belle for a camping trip, so I'm all ears and open for your suggestions on how best to proceed with this project. Winter is coming fast upon us here in the deep south, (28 degrees last night), so it looks like we'll have some time before springtime to git 'er done....er, um...git 'er started! Advice and observations welcome! Thanks, Corky
Post by vikx on Nov 25, 2013 22:46:39 GMT -8
My SCS heater is missing and I wish I had it. The heater in the Deluxe fired right up and worked perfectly.
Basically, you check the flue and innards for dust and debris, then light the pilot. Once the thermocouple senses heat, turn the heater to "ON" and it should fire right up..
On a good note, I'll be installing my first on demand water heater in the old heater space. Chimney in place, perfect.
Gonna junk the old water tank heater...
corky
1964 Shasta 16-SCS
Post by corky on Nov 26, 2013 20:14:59 GMT -8
My SCS heater is missing and I wish I had it. The heater in the Deluxe fired right up and worked perfectly. Basically, you check the flue and innards for dust and debris, then light the pilot. Once the thermocouple senses heat, turn the heater to "ON" and it should fire right up.. On a good note, I'll be installing my first on demand water heater in the old heater space. Chimney in place, perfect. Gonna junk the old water tank heater... Vikx: Is the heater in your Deluxe like mine? If so, can you tell me how to pull the cover to see the innards? Thanks! Corky
Post by vikx on Nov 26, 2013 21:05:33 GMT -8
The two louvered pieces lift out first. Just push up slightly and the bottom should clear the lip. The cover itself may be screwed in place or just lift up and out. Mine was screwed but it was easy to get to them after the louvers were out of the way. VK
corky
1964 Shasta 16-SCS
Post by corky on Nov 27, 2013 20:40:24 GMT -8
I got out to work on Ms. Belle for a while today, and decided to fiddle with the heater. I got the lower grate and face cover off pretty easily, (Thanks Vikx!), and it looks darned near new. Looks like all I'll need to do is scrub some heavy dust build-up down by the valve, check the fittings, and give it a try:  The burner is cast iron, (see above and below), and it looks like the flames transfer heat up the heat exchanger baffles to the vent above... ...and the pilot light is lit through the hole in the lower center of the baffle...  The upper part of the heat exchanger also looks new, but I may remove them to make sure the inside looks good too.  If anyone knows how to rotate these photos, (Vikx/Admin?), be my guest! They wouldn't post correctly from Photobucket.
Post by vikx on Nov 27, 2013 21:31:30 GMT -8
Are the photos upright at Photobucket? If you rotated them after uploading, they may not show correctly here. Not sure. Be sure your pictures are all rotated correctly before uploading and then see how it goes. Hope this helps.
zippidydoda
1964 Shasta SCS
Post by zippidydoda on Nov 28, 2013 22:32:58 GMT -8
Corky, Hey I'm new too! Loved your "find" story! I picked up an SCS also... trying to figure out if it is a 63 or 64. It does have a date stamp on the sink of 8-2-63. Where is yours from? I see you still have a plaque next to the door. Mine is from Pennsylvania.
Mine has the same "gold star" light surrounds. I wasn't sure if mine were original until I saw your pics. Thanks!
I have the same "air freshener" (like the one on your mirror) in my trailer also! HA-HA! Those must really be vintage and collectable!
Keep the pictures coming they are great!
59shastadeluxe
'59 Shasta Deluxe
Post by 59shastadeluxe on Dec 1, 2013 12:42:19 GMT -8
What a fantastic story on your find!
zippidydoda
1964 Shasta SCS
Post by zippidydoda on Dec 1, 2013 17:17:39 GMT -8
Corky, I knew I had seen a pattern for the Shasta Magazine rack! I found it for you! Here is a link! The actual template instructions are embedded and come up when you click on "Shasta Magazine Rack Template" Start at - www.freewebs.com/kc8jwa/shastamagazinerack.htmHope this helps you! And as I said in my other post where I shared my email I will send you a tracing of the actual "S" if you need it! Your fellow SCS friend!
corky
1964 Shasta 16-SCS
Post by corky on Dec 7, 2013 17:12:21 GMT -8
Rain Bonnet for Ms. Belle Well, after lots of rain and hand/arm surgery this week for ole Corky, I decided it was time to button up Ms. Belle for the winter.  I'll post some more pictures later, but this heavy-duty 11X19 tarp from Harbor freight oughta keep the roof leaks from doing any more damage while I mend me ole arm. You can't see it too well in this nighttime picture, but I've rigged the string so I it won't be too hard to lift the bonnet and sneak in the side door for some work later--there's more ole tinkerers than there are old doctors!! Corky
