flameout
1968 Shasta StarFlyte
Post by flameout on Jun 27, 2017 18:05:08 GMT -8
I really haven't given it much thought, until I started doing some reading. My 68 Shasta has a black water tank, but what do you do with the water from the sink and shower? Is seems like there is enough room underneath to add a long, narrow tank. I was reading about those totes, but they sure seem expensive for a hunk of plastic. I found this one thatnis a bit more reasonable. Could I just use this for my gray water? www.amazon.com/Tote-N-Stor-25606-Portable-Waste-Transport/dp/B0085KGOD4/ref=sr_1_5?ie=UTF8&qid=1498613815&sr=8-5&keywords=rv+waste+water+toteI even thought about maybe mounting it under the trailer to collect gray water, but 9" deep might be a but much. As you can probably tell, I'm new to this and we are going on our first camping trip with our new Starflyte in a couple of weeks. Tin Can Tourists is having a rally about 40 minutes away, and since it's so close, we can learn the dos and dont's and still be close enough to home if it's a disaster
Post by ladywendolyn on Jun 27, 2017 20:03:50 GMT -8
I am adding a 10 gallon grey under my kitchen sink in the cabinet. It is 10x8x16 I believe. It will then drain out the bottom into a pipe that exits alongside my black water tank. I was concerned about adding anything else under my trailer as it has a metal underbelly and is already pretty low. I think it will work for the odd time we boondocks and the rest of the time my sinks will drain into the full hookup hose.
flameout
Post by flameout on Jun 28, 2017 4:18:55 GMT -8
That's a good idea. Maybe I'll eventually do that too, as I really don't think my shower will be getting that much use. I did order that 11 gallon Tote-n-stor I had in my origial post. Seems small enough to store and large enough to squeak by if we need it
Post by ladywendolyn on Jun 28, 2017 7:47:42 GMT -8
