bev
Post by bev on Jun 4, 2017 12:09:34 GMT -8
RinTin
Post by RinTin on Jun 4, 2017 18:04:53 GMT -8
Unless it gets wet, like absolutely sopping wet, wood does not conduct electricity.
Post by vikx on Jun 4, 2017 22:04:19 GMT -8
Not only that, a ground is a ground is a ground. On a 12 volt system, the hot must touch the ground to short out. So, the ground bracket can be attached to anything that isn't Hot. The hot wire must never come into contact with a ground. That would be the metal frame, skin, ground wires, etc.
alilbs
Post by alilbs on Jul 21, 2017 22:29:52 GMT -8
Speaking of grounds, I have a 58 airflyte,I'm up dating the electrical. I installed a 15 amp breaker system and new 12 system. Can they both be grounded to the frame?
Post by vikx on Jul 22, 2017 21:40:16 GMT -8
Yes, they both need to be grounded to the frame. Ground each separately to different frame attachments.
alilbs
Post by alilbs on Jul 23, 2017 6:11:06 GMT -8
Thanks
