Post by nccamper on Apr 19, 2017 17:29:38 GMT -8
Welcome!
The fan goes in exactly like a passive vent but you need it wired for 12 volt. It works wonders at keeping the air moving but it can be loud. I think it’s great.
Post by joebaker3637 on Apr 19, 2017 22:56:24 GMT -8
I don't have a 12 v system. Who should I talk to my local rv dealer?
Post by vikx on Apr 20, 2017 21:21:57 GMT -8
I'm seeing at least one 12 volt light above the rear bunk. Do some research...
Post by joebaker3637 on Apr 21, 2017 1:29:37 GMT -8
There are wires in the cabinet I'm pretty sure it just hooks to a battery
Post by vikx on Apr 21, 2017 20:08:33 GMT -8
I rewired our 57 Shasta with a complete 12 volt system.
The wires in the cabinet are connected to an incoming set of wires from the fuse block in the dinette. I ran the wires across the lower kitchen cabinet and made a chase to go into the upper cabinet to a J box. That provides power to the light over the bunk. From there, I ran them across the window area into the next cabinet/J box. Cut a small hole in the cabinet ceiling and run your wires for the Fan.
I've done several trailers this way. It's fairly easy, if tedious. If you PM me, I can share photos via email.
