bronco638
Post by bronco638 on Oct 4, 2013 10:12:40 GMT -8
On a 1962 Broken Arrow Tepee, this is the rear window. It is a crank out unit. Can anyone tell me the manufacturer? And, yes, it's tinted so dark, it looks like it's painted black. My lovely wife with her "I'm concentrating" face. Here's the front window. It used to be a crank out unit, like the rear, but was converted to static (for some reason). The channel, that allows the window to pivot open, is still there, just below the brow. I believe the opening measures 18.25" high by 59.5" inches wide. I would like to know the name of the manufacturer and am interested in buying a recovered unit if anyone has one. Cranks and supports are available, I think, thru VTS (if necessary). This window current leaks (in the lower corner, closest to you). So, it will have to come out to be resealed anyways (which is on the list of Winter projects). It would be great to remove it and replace it with a window frame that's supposed to be there. Any info is greatly appreciated. Thanks, Dave.
bronco638
Post by bronco638 on Oct 9, 2013 11:08:47 GMT -8
No one huh? Rats.
It would really be cool to be able to get that front window back to original but I do have the option of replacing it with two windows that use a Hehr style 'pop & prop' mechanism (as opposed to the crank out style). If I was really ambitious, I suppose I could convert from 'pop & prop' to crank out.
Post by mobiltec on Oct 10, 2013 7:07:31 GMT -8
Have you tried the link to Chris out in the Mojave Desert that is on my links page on the website?
bronco638
Post by bronco638 on Oct 10, 2013 10:52:33 GMT -8
Shoot! I have not. Thanks for the reminder Larry.
Post by mobiltec on Oct 10, 2013 12:25:42 GMT -8
