csrain
Post by csrain on Dec 18, 2016 14:29:13 GMT -8
Hi all! This is my first post on this site. Seems like a huge wealth of knowledge on these boards, can't wait to learn a ton! So, I'm completely new to travel trailers so I'm still trying to navigate resources on repair. I just bought a 1972 Shasta Compact (13'). Overall, it seems to be in decent shape with the exception of some interior wood panels. Seems like water damage, so I'm assuming some of the frame boards will need to be replaced as well. I was looking for a complete step-by-step but haven't found exactly the instructions I need. Here's some pictures to help me explain my situation: 20161218_144449 (1) by csrain, on Flickr 20161218_144456 by csrain, on Flickr So what's sort of the steps here? Just not sure if this is something that can be repaired from the inside. Or if I need to remove the back skin and work from the outside. Does the floor have to be removed? I'm really not trying to do a complete restore right now. Just need to get the bad stuff fixed in preps for a move. Will be able to do a solid reconstruction next spring. Thanks!
Post by Ten on Dec 18, 2016 15:20:34 GMT -8
Welcome to the madness. The real proper way to fix this damage is to start outside-in. Access to all the framing as well as the interior walls is made from the outside. The interior panels overlay the walls, and can't really be pieced in without losing the structural integrity of the overall build. What you are seeing is typical to nearly all the Shasta models past 1968. The rear windows leak around them, as do the J-rails at the edges, after several years of putty drying out, and allows water to seep in around the framing and down through the rear wall. Water always runs downhill, so it rots from the bottom up. Usually the corners are where the damage starts, going up the wall corners and outward into the floor ply. The interior wall panels suffer de-lamination from the seepage. My advice would be to do it once and do it right. If you are concerned about moving it, and are planning to replace framework and panels anyway, you can add cheater blocks to the inside to tie it together and shore up the framing strength. Adding t-post type supports from ceiling to floor will help support the weight of the roof structure and help to prevent collapse. This type of temporary support will be easy to remove when you get to the real repairs. Don't try to rush things, there are lots of resources to help understand the stuff you can't see. I used to have a load of blogs and photos of repairs from just this type of trailer but have lost most over the last couple years. I'll try to remember some of the ones I had and get you links to see them. This is the rear of a '69 Compact. Don't feel like the Lone Ranger!
Post by Ten on Dec 18, 2016 15:33:02 GMT -8
msgoehring
1957 Westerner Deluxe
Post by msgoehring on Dec 18, 2016 18:11:12 GMT -8
Also there are a couple of resources you should really check out. They are very helpful and full of all the information you could ask for about repairing or restoring these wonderful vintage trailers. The first resource is mobiltec. He makes videos and posts them on YouTube of his work sharing how to do everything on a trailer from start to finish. His website is: www.cannedhamtrailers.com and I recommend you watch this video first so you better understand why these things have to be repaired from the outside in: www.youtube.com/watch?v=hDdpZgSD1JM . He does all these videos for free to help others who are interested in vintage trailers, he does accept donations from his website if you find his information as important as I have and are so inclined to help. Next is a wonderful repair manual put together by another long time member that restores trailers whose forum name is vikx. You can find the manual here : vintagetrailerrepairmanual.weebly.com With these two resources and all the people here who have or are still working on a compact you should be set pretty well. Everyone here is very helpful and will answer any questions you come up with.
