Post by danrhodes on Dec 2, 2016 13:28:18 GMT -8
I can find some stamping, but no ball size. The trailer came with a 1-7/8" ball, but the PO was a bit of a hoarder, so I'm not sure it went with that trailer. My first tow banged a bit, but that could have been the receiver.
Post by vikx on Dec 2, 2016 22:35:10 GMT -8
Try a two inch ball in the coupler. It won't close if it is 1 7/8"....
Post by rogerthedodger on Dec 3, 2016 8:01:02 GMT -8
Mine takes a 2" ball, Hadco tongue and brakes.
Post by danrhodes on Dec 3, 2016 15:00:22 GMT -8
The 1-7/8" is a bit loose. goo.gl/photos/aaBQg3AXqsLTq9Rf9The 2" ball seems to fit. Should it be totally tight? If so, thanks PO for nearly killing me again
Post by rogerthedodger on Dec 3, 2016 15:54:58 GMT -8
2" looks good to me. I think you got bit by the cheap po bug. Haha
Post by danrhodes on Dec 8, 2016 8:43:39 GMT -8
Frolicking
Frolic
Post by Frolicking on Feb 2, 2017 7:48:32 GMT -8
Dan, Did you ever try this method? We were told ours was 2in, but it seems loose.
Post by mrmarty51 on Feb 2, 2017 8:01:16 GMT -8
The ball should not be totally tight. If it were it would score the chrome on the ball. If the hitch is for a 1-7/8ths inch ball, a two inch would not even fit into the hitch, unless it was totally hammered out. If that was the case You would be able to see the damage. if that video is of Your hitch, You are good to go with the 2" ball. The adjustment procedures described in the adjustment page is good information. The hitch could possibly be adjusted until it is too tight then, it would be tough to get the latch shoved down. I also use a very sparingly amount of grease on the ball to prevent squeaking and galling of the chrome. A lot of controversy on that subject too. LOL I keep a plastic shopping bag, with a paper bag inside of it to store the receiver and ball in when not in use. Like I said, very sparingly on the grease on the ball. After the first tow of the greased ball and I disconnect from the hitch, i wipe down the ball so it is clean. there will then be enough grease inside of the hitch to last for many a mile. The ball may have to be wiped off again, after each pull and after several more pulls.
Post by danrhodes on Feb 2, 2017 8:35:40 GMT -8
Dan, Did you ever try this method? We were told ours was 2in, but it seems loose. Turns out my coupler is a different style than the one from the article. It has a pin that moves up and down, pushing a sliding piece forward to capture the ball. I finally got a 2" ball and it seems to fit OK.
Frolicking
Frolic
Post by Frolicking on Feb 2, 2017 9:23:16 GMT -8
Thanks for the response! My coupler is like yours. I'll be trying the 2-5/16 ball this weekend.
Post by danrhodes on Feb 2, 2017 10:48:10 GMT -8
Thanks for the response! My coupler is like yours. I'll be trying the 2-5/16 ball this weekend. There might be an adjustment screw/bolt inside there, but I couldn't see how to turn it. The 2" ball fit, so I stopped trying to fix it. Does yours have a model name and number stamped on top?
Frolicking
Frolic
Post by Frolicking on Feb 2, 2017 11:25:00 GMT -8
Thanks for the response! My coupler is like yours. I'll be trying the 2-5/16 ball this weekend. There might be an adjustment screw/bolt inside there, but I couldn't see how to turn it. The 2" ball fit, so I stopped trying to fix it. Does yours have a model name and number stamped on top? It probably does, but it's painted over and I gave up looking for the VIN after much scrubbing with a wire brush. I'll be getting one that attaches to my drill. I'll look for the model number then.
Post by vikx on Feb 2, 2017 20:52:21 GMT -8
Frolicking, I highly doubt your trailer needs a 2 5/16 ball. They weren't used much way back when. Also, I always use a 1" shanked ball. Most class III ball mounts today require one anyway.
