harryinwis
1968(?) Woodsman
Post by harryinwis on Nov 26, 2016 19:54:32 GMT -8
I just pulled my drum off my trailer. I don't think they have been off in decades. I would like to put new bearings into the old drums but how do you determine bearing size? Someone told me there are numbers stamped on the edge of the bearing itself. I will look for that....but I don't want to remove/trash the grease seal until I KNOW I can get replacement parts.
Can I just use a caliper on the spindle to determine size?
Also, has anyone put electric brakes or modern hubs on a vintage Fayette(?) axle? I removed the wheels and found 1 "star" pattern rim and the other one had just a big round opening in the center. Time to address this!!!
Thanks for any advice or help
Post by mrmarty51 on Nov 27, 2016 7:54:50 GMT -8
Easiest way to remove the inner cone/cup and seal is to first remove the nut and washer, then determine if the nut will pass through the outer cup, if so then start the nut back onto the spindle by several threads then, using the hub like a slide hammer, rapidly pull the hub towards You. This will leave the inner cone and seal on the spindle and usually without damaging the seal. If the cones and cups have no pitting or galling I would pack the bearings and put them back on. The old seals can be reused if they are not hard and cracking. Cones and cups will have numbers stamped into them, usually they will be Timken bearings. If You want to go to electric brakes then the drums and backing plates will need to be replaced. If it has drums then it may be possible to find backing plates and electric brakes that will fit Your drums. I would try a trailer supply store to see what they have in stock. If the seals are pliable and not cracked but get slightly distorted from removing them, they can be placed on a block of wood and tapped back to flat again.
