Post by nccamper on Nov 11, 2016 14:44:31 GMT -8
I like this light but as you can see the lower left screw hole is broken. Any repair idea come to mind that will not brake as the screw is tightened?
Deleted
Post by Deleted on Nov 11, 2016 17:18:18 GMT -8
Hey nccamper, what about rubber washers on either side of the screw, under the head and behind the plate?
Post by danrhodes on Nov 11, 2016 17:43:22 GMT -8
I'm ghetto trailer guy, so I'd just use washers on all 3 screws. Once the good 2 are in, the other will hold.
Post by nccamper on Nov 11, 2016 19:39:23 GMT -8
Basically, you both think sandwiching the screw will create enough grip to hold it in place? Here is the problem, if it doesn't work my fall back is a Bargman light like this and the holes will naturally change.
Post by Ten on Nov 11, 2016 21:20:29 GMT -8
Go with the Bargman. Patch the old holes up and cover what you can with the plate. Then mount that light to a plate cut to its contour and place it as a porch light.
msgoehring
1957 Westerner Deluxe
Post by msgoehring on Nov 11, 2016 21:49:44 GMT -8
Post by vikx on Nov 11, 2016 23:31:13 GMT -8
Yeah, that's an old porch lite... I'd change it out to the old norm license plate light. They are easy to find and adapt. Then you might be able to find a "fix" for the porch light bracket.
Post by nccamper on Nov 12, 2016 5:05:47 GMT -8
Forester used a porch light for the taillight? I never questioned what kind of light it was. It had a license plate bracket that worked perfectly with this kind of light so I know it was original. I think Bargman will be the way we'll go.
Deleted
Post by Deleted on Nov 12, 2016 18:26:17 GMT -8
You know the old saying... one manufacturer's porch light is another's license plate light. Haha
bev
Post by bev on Nov 13, 2016 3:53:32 GMT -8
can you just grind off the remnants of the third whole and polish it up? it would think that 2 carefully and properly installed screws would be strong enough...that is if you are really trying to salvage the light.
Post by nccamper on Nov 13, 2016 9:39:05 GMT -8
can you just grind off the remnants of the third whole and polish it up? it would think that 2 carefully and properly installed screws would be strong enough...that is if you are really trying to salvage the light. When the third screw is out the license bracket floats a little at one corner. Unfortunately, it's three screws or nothing.
handkey
1964 Forester 14
Post by handkey on Nov 14, 2016 19:41:40 GMT -8
You know the old saying... one manufacturer's porch light is another's license plate light. Haha Porch light? Forester ? What apx yr forester ? Pre 1963? I'm working on a custom license plate light that I will be putting on my 68 forester project .
Post by nccamper on Nov 14, 2016 19:51:06 GMT -8
You know the old saying... one manufacturer's porch light is another's license plate light. Haha Pre 1963? A 1962 Forester.
Post by mrmarty51 on Nov 15, 2016 0:12:52 GMT -8
If the light is of a plastic material, get some J-B Plastic weld. J-B Plastic weld can be formed and the flange can be made then after it cures, it can be sanded and drilled so it looks good as new. The J-B Plastic weld cures in a very short time so when it is mixed, It can set for a few minutes to stiffen up then formed to the approximate shape. I used some to glue a plastic boss back onto the inside of the door panel on My Chevy pigup. After it ad cured, I think it says a 1/2 hour, I let it set for four. I went back to the garage and took a hold of the repaired piece and it held as if it had never busted. I was impressed with the results. If it is steel, I think the plastic weld will hold to that too. If not then J-B weld could possibly gain the same results.
