theresa
Post by theresa on Jun 12, 2016 12:44:19 GMT -8
This is as far from vintage as you could possibly stray, but might be a neat solution for someone to get heat and air into their vintage trailer without having to cut a lot of extra holes. Not sure how you would retrofit to bumper mount it... (click below to go to the site to see it.... I didn't take the time to load the photo). Portable Heat Air
Post by vikx on Jun 12, 2016 20:27:58 GMT -8
I think it's a viable option. Spendy, but should work just fine. I would probably have a temporary set up rather than mount it on the trailer or bumper. That way, no need to drag it along in mild weather.
theresa
Post by theresa on Jun 13, 2016 13:53:24 GMT -8
I think it's a viable option. Spendy, but should work just fine. I would probably have a temporary set up rather than mount it on the trailer or bumper. That way, no need to drag it along in mild weather. I hadn't even thought about a temp. set-up (i.e. a small table outside of the trailer while at the campground?). It is very expensive, but if you are buying a separate A/C and heat source of some time, that brings it a little more into a realistic price range. And perhaps with some creative shopping, one could be found cheaper. SaveSave
