trotwood56
Post by trotwood56 on Apr 22, 2016 12:15:45 GMT -8
I need to install a propane system in my camper. All its going to run is a two butner stove. What kind of gas line should I use? Do you run the lines in the trailer or underneath it? Suggestions for regulators and hose?
I would appreciate suggestions.
Thanks guys.
Post by danrhodes on Apr 22, 2016 12:38:53 GMT -8
Just to add to the questions, I know it's not legal to use rubber hose, but is there any really reason not to?
Post by vikx on Apr 22, 2016 21:39:41 GMT -8
Use the original copper tubing if you've got it. It is twice as thick as today's and very strong. Black iron under the trailer teed into flared brass and copper tubing up into the trailer.
Hose is not legal inside any RV because it is more suseptable to damage and in case of fire, easy to ignite...
trotwood56
Post by trotwood56 on Apr 23, 2016 4:07:51 GMT -8
Sounds good. Looks like I'll be running hard line. Unfortunately the last owner trashed the gas lines and electrical trying to "fix" it. JB weld is probably not a proper fix for joining gas line
Post by Ten on Apr 23, 2016 7:42:38 GMT -8
Query to the experts: Isn't there a flexible line that is rated for propane, something similar to the idea of PEX line for water? Thought I read that somewhere. I just read the JB Weld package, and it says it can be used for plumbing. Propane is essentially plumbing, but I still would not recommend using it for jointing lines for propane. In fact, the fewer joints the better. If it were me, I'd replace it all. It'll be well worth the investment. And it will be a relatively small investment since you are only planning one appliance. You can run soft copper line, so that you can bend it where it needs to bend, an also not have any unnecessary joints. Be sure to flare properly and check your seals. I would recommend using an automatic-changeover regulator if you are using dual tanks. They run about $50-60, but are a nice feature. It allows one tank to run till it's gone, then indicates the empty tank so that you are not left without any. I also like the braided pigtail hose for the tank connection. The regulators and hoses are readily available through VTS: www.vintagetrailersupply.com/category-s/110.htmOr VintageCampers: www.vintagecampers.com/parts.php?category=LP%20Gas&sub=Hoses%20%26%20Regulatorsor most RV places. I have found some suppliers that sell on eBay as well. Just to illustrate:
trotwood56
Post by trotwood56 on Apr 23, 2016 7:47:46 GMT -8
I'll probably end up using coper line. I'm only doing a Single tank set up is a regulator that you would use on a propane grill ok?
Post by vikx on Apr 23, 2016 21:13:52 GMT -8
A BBQ regulator is not legal on an RV of any type. The legal regulator is defined as "two stage". They can either be single tank or double, but both need to be two stage. Do a search on RV propane regulators and I believe you'll find more info.
I've heard of some sort of yellow Pex like lines in modern RVs but the techs were really critical of it. Not sure if it's still legal/being used. Corrugated flex lines are not used in RVs for obvious reasons.
And finally: JB WELD WILL NOT SEAL GAS LINES!!
pam
Serro Scotty 69
Post by pam on Jun 1, 2016 6:58:37 GMT -8
This is the point when my eyes roll back in my head. So much valuable and important information and I don't want to miss a single piece! Looking at reworking the kitchen which requires moving the propane lines (only a 2 foot extension)....however, still tricky for someone who has only been at this for 3 years and 2 campers.
