tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Apr 14, 2016 9:25:08 GMT -8
Greetings! I have a new water filler neck to install but the hole from the previous filler is just slightly bigger than the flange on the new one. I was thinking of installing a backing board on the inside of the skin (the interior walls are out so I have access) but I am stumped as to what to use as the "gasket" on the outside of the skin to cover the edges of the old hole. I was thinking of a round or square piece of white plastic or foam.
Any and all suggestions are most welcome.
trotwood56
Post by trotwood56 on Apr 14, 2016 9:55:51 GMT -8
I had a similar problem on my camper. I Used a hole saw to cut out an aluminum patch big enough to cover the original hole. Then I put a treated wood backing plate on the inside of the trailer, I drill a hole through the patch big enough for the new filler neck then I ran screws through the filler neck bracket, the patch, and into the wood backing plate.
tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Apr 14, 2016 9:59:03 GMT -8
Trotwood56 - did you have to do any filler work after the install to cover up any gaps between the aluminum patch and the neck bracket?
trotwood56
Post by trotwood56 on Apr 14, 2016 11:53:03 GMT -8
No, I used a sheet of aluminum that matched what was on the side of my camper. I cleaned up the edges of the patch to make it look symmetrical, I also used a little bit of clear silicone adhesive to make a water proof seal around the patch and new filler neck. I don't know what kind of camper you have, but mine is unpainted aluminum on the outside. My filler neck also made a really smooth seam with the patch which i think looks much cleaner without adding filler or sealant. It may be easier to get a slightly oversized filler neck, or one with a bigger mounting plate , that is if you have camper skin with crips or texture that is hard to work around. my skin is flat with only small brakes every 6-8 inches. One other option I've seen is to patch the filler neck whole, and instead use a oneway rv hose connector that is mounted under the camper by drilling a hole in the floor for the line. The issue with that is its not as easy to hook up a hose and you can only fill your tank from the outside with a pressurised water source, you can't just pour water into the tank. I use a one way hose connection.
Post by vikx on Apr 14, 2016 20:47:05 GMT -8
A patch is what I would use too. It can be round or square to match the other trailer inlets and flanges. I seal mine with 1/2 x 1/16 butyl tape then screw it tastefully to the original skin. The backer will provide a good grip for the screws. Here is a nasty PO mess on my Aljo: The plate: And the inlet, this is the best photo I have but it really didn't look patched:
tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Apr 15, 2016 3:50:21 GMT -8
Excellent - thanks! I will get on it this weekend!
Post by vikx on Apr 15, 2016 20:34:19 GMT -8
I forgot to mention sealing all the extra holes with OSI gutter seal before the patch. OSI comes in a capped tube which makes it really easy to use. (Lowes)
Most patches don't need to cover such a mess, just shrink the hole a bit...
