Post by mel on Mar 25, 2016 14:59:18 GMT -8
Has anyone ever seen one of these before? It says 6V lantern battery on it and has some wires hooked up to it. But my lantern does not have wired hooked up to it only gas, and looks completely original and un-tampered with. The wires go under the camper and hook into the wire bundle on the tongue, so the tow lights wires im guessing to charge it.
Post by mel on Mar 25, 2016 15:09:42 GMT -8
Post by bigbill on Mar 26, 2016 7:44:47 GMT -8
My guess was this trailer was towed by a vehicle with a 6 volt system and if so this was most likely the battery for the break away switch.
Post by ladywendolyn on Mar 26, 2016 7:55:52 GMT -8
I have seen those lanterns on Etsy. If you look you find one..
Post by Ten on Mar 26, 2016 9:08:14 GMT -8
mel , your Compact does not have a dome light installed in the ceiling anywhere with a switch directly on the side does it?  I know they used these in the Airflytes and the 16SC models in the early 60's, the one above is in my Airflyte. It had a pair of leads in the top of the cupboard to the right, and used one of those 6-V lantern batteries to power it. It made it a stand-alone light independent of any of the other wiring/lighting systems.  Those batteries were used a lot in the 60's for all different types of lanterns. Some had the screw posts like yours, and later they were made with spring-top contacts which would basically press-fit inside the lantern casing.   Since your trail leads you back to the trailer wiring harness, I would think bigbill's idea probably the most likely. Even if the vehicle were not 6-v, the lantern battery at full should be enough current to activate brakes in an emergency situation.
Post by mel on Mar 26, 2016 13:44:28 GMT -8
Ten, no dome lights or any other lights added. Very interesting about the brake away.
Post by bigbill on Mar 26, 2016 17:04:44 GMT -8
Law required a trailer mounted battery to operate brakes in case of a break away enough to stop trailer so many of them used lantern batteries to stay legal. They were cheap and plentiful. Some trailers had a tongue mounted case to carry them in.
Post by mel on Mar 26, 2016 17:28:43 GMT -8
Law required a trailer mounted battery to operate brakes in case of a break away enough to stop trailer so many of them used lantern batteries to stay legal. They were cheap and plentiful. Some trailers had a tongue mounted case to carry them in. Pretty interesting, thanks for sharing
Post by Ten on Mar 26, 2016 19:13:55 GMT -8
Break -away switches still have to be powered from the trailer. Some of the modern kits include a battery-pack that recharges from the vehicle when hooked to tow wiring. It can also be run from the battery which powers the 12-V system in the trailer itself.  In the event of a break-away, the trailer would no longer be connected to the vehicle battery power, thus requiring a power source contained in the trailer's system, to apply the electric brakes.
Post by cowcharge on Mar 30, 2016 7:32:33 GMT -8
rpr
Post by rpr on May 29, 2017 21:07:19 GMT -8
I do not recall my 14 ft. 1960s trailer having any type of brakes. It was stopped by the behemoth pulling it.
