Post by universalexports on Aug 11, 2013 12:22:57 GMT -8
well I am putting in a new Galley, to hold a fridge, 2 induction stove tops and a two compartment sink. it is slow going, figuring what I need to do as I go along, what do I need to use the build the counter top out of, 1/2 plywood? 3/4 inch ply, MDF??? here it is so far.
61 Shasta
Post by 61 Shasta on Aug 11, 2013 12:59:59 GMT -8
I would stay away from MDF, it is heavy and if any water does migrate into it, it will deteriorate very quickly. Based on your layout, you could probably get by with 1/2 inch plywood by putting another stiffener above the fridge to help prevent any sag from occurring in this space. It is the only large working surface that could be suspect. Now, having said all of that, if I were doing this in my unit, I would use 3/4 inch plywood. It is the best (in my opinion) counter top base material.
Post by vikx on Aug 11, 2013 23:08:37 GMT -8
I agree, no MDF. Also remember to insulate above the fridge to keep the counter top an even temperature.
Post by universalexports on Aug 23, 2013 16:12:54 GMT -8
well I am building a new Galley to fit my needs. it will hold my fridge, 2 induction stove tops, and a dual compartment sink. i'm using 1x2 lumber and covering it with 1/4 inch birch. I've got the frame built, 3 drawers with slides, and the outside birch piece cut out. I will post pics as it progresses, thoughts? ideas?
Post by Hamlet on Aug 23, 2013 16:27:35 GMT -8
beautiful!
Post by universalexports on Aug 25, 2013 13:17:12 GMT -8
didn't get a lot done yesterday, I got the 1/4 inch birch skin put on the frame of the galley, took forever to measure and cut it out right, then sand and shellac.
Post by universalexports on Aug 25, 2013 16:26:54 GMT -8
got 2 drawers completed this evening with new reproduction door handles from rejuvenation.com still have do some alignment and tweaking to them where they need to be.
Post by bigbill on Aug 25, 2013 18:24:00 GMT -8
If you keep at it you will be the envy of the crowd, looking good.
Post by cowcharge on Aug 28, 2013 5:13:03 GMT -8
Nice!
smccusk
63 SC Restoration in progress
1963 Shasta SC
Post by smccusk on Aug 28, 2013 6:40:26 GMT -8
Looking good, I'll bet your project progresses quickly at this point.
txoil
1960 Shasta Deluxe 19
Post by txoil on Aug 28, 2013 8:56:06 GMT -8
Great job!!!
Post by mobiltec on Aug 29, 2013 13:01:33 GMT -8
Too hot to work here so keep up the good work. Dang I like that floor.
paigenmarc
1957 Siesta
Post by paigenmarc on Aug 29, 2013 14:42:54 GMT -8
WOWZA!
Post by 62shastacrazymom on Aug 29, 2013 22:21:28 GMT -8
That is a dream kitchen!! Good job!! Looks amazing
Post by universalexports on Sept 1, 2013 13:43:25 GMT -8
I got a little more done on the Galley, all shelves doors completed and the top cut out. I used 19/32 plywood for the top, it's between 1/2 and 3/4 inch. That way when I add the laminate top I can use 1/4 inch trim and it should fit well, the wife is wanting a white marble laminate top.
