Post by Teachndad on Dec 27, 2015 22:23:19 GMT -8
Hi, Can I replace the light socket on a wedding cake lens base? In the one pictured below, the lightbulb was rusted into the socket and I had to destroy the lightbulb base to get it out. The socket is still intact, but it has no bottom anymore.
Post by bigbill on Dec 28, 2015 14:50:39 GMT -8
Many times I purchase either repair parts from NAPA, or if they don't have available what I need then I purchase an inexpensive light that has the parts then remove them and install in old light. Also if reflector is bad you can glue a layer of alum foil over it for a bright reflective surface.
Post by nccamper on Dec 28, 2015 16:01:47 GMT -8
I bought a light socket like that on ebay. It didn't have the metal plate it sits on. It came on a very, very slow boat and took three weeks to arrive.
Post by Teachndad on Dec 28, 2015 19:57:54 GMT -8
Hi,
I need to remember to try my local auto parts store first. I didn't think of that. BigBill, you are ever the resourceful one with your suggestions.
eBay of course and then there is also VTS. They have the light socket for less than 4 bucks and shipping was about the same and I never left the house. I figured it was worth a shot rather to go to buying a full base and lens package.
Turns out the Scotsman comes with Reflecto Lite lenses which are 7" in diameter. The lenses they sell at VTS are bargeman 99 size and 6.5" in diameter. more retrofitting..., or gamble with a $4 part.
Cheers,
Post by bigbill on Dec 29, 2015 7:10:26 GMT -8
I bought a light socket like that on ebay. It didn't have the metal plate it sits on. It came on a very, very slow boat and took three weeks to arrive. If you pick up a socket with out the angle mounting tab you can make a tab then remove the wires and bulb base plate from the new socket and solder the socket to your new angle you made then reinstall the base plate and wiring. this is fairly simple and you wind up with a new socket for your light.
azshastanut
1957 Kenskill 16T
Post by azshastanut on Dec 29, 2015 10:49:21 GMT -8
Sockets with brackets are available at Vintage Trailer Supply. They have both single and double filament.
Post by bigbill on Dec 29, 2015 13:19:14 GMT -8
Sockets with brackets are available at Vintage Trailer Supply. They have both single and double filament. Yes but can you go pick it up and have the light fixed in a couple of hours? Sometimes you have years and some times you are ready to leave on your vacation now.
Post by mobiltec on Dec 31, 2015 19:29:26 GMT -8
Im pretty sure you can get the reflecto lenses at Napa or many other non auto zone parts stores.
Post by Teachndad on Dec 31, 2015 22:19:49 GMT -8
Sockets with brackets are available at Vintage Trailer Supply. They have both single and double filament. HeY Gary, thanks for for the suggestion. I ordered one and it should be here soon. rod
Post by Teachndad on Dec 31, 2015 22:28:24 GMT -8
Im pretty sure you can get the reflecto lenses at Napa or many other non auto zone parts stores. Thanks Larry, I'll give that a try. Cheers, Rod
Offspringin
1976 Apache Ramada
Post by Offspringin on Feb 16, 2016 21:57:17 GMT -8
Many times I purchase either repair parts from NAPA, or if they don't have available what I need then I purchase an inexpensive light that has the parts then remove them and install in old light. Also if reflector is bad you can glue a layer of alum foil over it for a bright reflective surface. Yup. Did this with the Shasta. Similar taillights. Cleaned up the original backplates. Took apart a pair of new trailer lights for the sockets. Riveted those to the original backplates. Worked like a charm since. You would never know it from outside the lense.
Post by cowcharge on Feb 18, 2016 10:09:15 GMT -8
Oddly enough, the LED bulbs I just bought at NAPA came with a socket on one of the bulbs in the 2-pack, because the sales display has a little solar panel and contacts to touch the packages to see the bulbs light up. So if you happen to be looking for LED bulbs anyway, go to NAPA and get a free socket.
Offspringin
1976 Apache Ramada
Post by Offspringin on Feb 18, 2016 10:15:35 GMT -8
Oddly enough, the LED bulbs I just bought at NAPA came with a socket on one of the bulbs in the 2-pack, because the sales display has a little solar panel and contacts to touch the packages to to see the bulbs lit. So if you happen to be looking for LED bulbs anyway, go to NAPA and get a free socket. Score!
