Deleted
Post by Deleted on Nov 11, 2015 12:13:36 GMT -8
Ok friends I have come to realize the rot wasn't just surface, its all the way through. This photo doesn't scare me, it will be beautiful and solid with new wood. I know I can do this! Friends I was wondering what the proper way to replace these rear boards that are rotted. It's rotted to the left of this photo as well . That board with rot goes forward about a foot and a half from the rear, and the next board up is in good shape. What steps and in what order. If theres another good thread already on this can you direct me? Thanks in advance, I wasn't sure if this was exterior or interior. LOL
Post by danrhodes on Nov 11, 2015 14:56:32 GMT -8
Post by mobiltec on Nov 11, 2015 15:41:58 GMT -8
Ok friends I have come to realize the rot wasn't just surface, its all the way through. This photo doesn't scare me, it will be beautiful and solid with new wood. I know I can do this! Friends I was wondering what the proper way to replace these rear boards that are rotted. It's rotted to the left of this photo as well . That board with rot goes forward about a foot and a half from the rear, and the next board up is in good shape. What steps and in what order. If theres another good thread already on this can you direct me? Thanks in advance, I wasn't sure if this was exterior or interior. LOL The 57 Westerner partial rebuild will help you a lot. As for the floor you can watch the 57 Shasta series for that.
Deleted
Post by Deleted on Nov 11, 2015 15:43:06 GMT -8
You got that right thanks! I will take a look at that.
Deleted
Post by Deleted on Nov 11, 2015 16:25:43 GMT -8
So mobiltec I have glanced at a couple of the floor videos on the 57 Shasta. I saw the whole front was opened and removed. I don't know if this is something I have to take the skin off for or not. As you see the photo there's framing on top of the floor that the PO put on. So could remove that and remove those rotten boards from inside fairly easily I believe. I don't even know though if the original framing was reattached to the floor, because this had been replaced a few years ago. But if not I can definitely attach it to the new boards. A leak had ruined it pretty quick, under laminate tile. Eek! I do love your videos.
Post by mobiltec on Nov 11, 2015 17:28:06 GMT -8
So mobiltec I have glanced at a couple of the floor videos on the 57 Shasta. I saw the whole front was opened and removed. I don't know if this is something I have to take the skin off for or not. As you see the photo there's framing on top of the floor that the PO put on. So could remove that and remove those rotten boards from inside fairly easily I believe. I don't even know though if the original framing was reattached to the floor, because this had been replaced a few years ago. But if not I can definitely attach it to the new boards. A leak had ruined it pretty quick, under laminate tile. Eek! I do love your videos. Well first off, for me to understand you we have to get our terms in order. The floor is made of plywood and boards are long skinny pieces of wood like the framing or skirt boards. Framing on top of the floor will have to be removed. The plywood floor is only connected to the joists underneath and the chassis. So that can be removed without tearing the trailer open. Any of the wall framing must be replaced from the outside though so if any of those or the skirt boards at the bottom of the wall framing will require removing or lifting up the metal skin to access. From what I can see it looks as though you have two sets of wall framing. One set that the metal skin is attached to which mounts to the side of the trailer and one for the interior paneling that sets on top of the floor. Never seen that before so I don't know what to tell you about that.
Deleted
Post by Deleted on Nov 11, 2015 17:48:35 GMT -8
Oops! Yes plywood is the word of choice for floor! Excellent I follow what you're saying. That helps me greatly. In yout videos i see there seems to be much more to the floor than just the plywood. Im a bit concerned. Becaise thats all i have as a floor. Maybe if the undercoating was able to be protected well then that woulf be ok. I dont know. I'm never in a rush for an answer , but either you or someone else always seems to answer soon. I appreciate it. Yeah actually like the second framing he did on the top of the floor, for the sake of a square and straight up wall. But gonna have to remove that for sure to get the *plywood* out. Haha. Thanks sir.
Post by mobiltec on Nov 11, 2015 18:51:02 GMT -8
Oops! Yes plywood is the word of choice for floor! Excellent I follow what you're saying. That helps me greatly. In yout videos i see there seems to be much more to the floor than just the plywood. Im a bit concerned. Becaise thats all i have as a floor. Maybe if the undercoating was able to be protected well then that woulf be ok. I dont know. I'm never in a rush for an answer , but either you or someone else always seems to answer soon. I appreciate it. Yeah actually like the second framing he did on the top of the floor, for the sake of a square and straight up wall. But gonna have to remove that for sure to get the *plywood* out. Haha. Thanks sir. No problem Rich. And as far as the laminated two part floor in the Shasta is concerned, that's something that I would not do if I were to build a trailer from the ground up. Shasta seemed to think that it was a good idea for insulation purposes but the half inch plywood floor was a mistake. If I were to do it over I would replace the entire floor with a full one inch ply instead of the two half inch pieces. That soundboard squishes over time and then the entire trailer becomes loose as it floats on the chassis. And that sound board offers no support so the half inch plywood gives under weight when you walk on it. Bad bad all the way. But that's Shasta for you LOL... They cheaped out any way they could.
Deleted
Post by Deleted on Nov 11, 2015 19:29:14 GMT -8
More peace of mind! It sure is crazy how they cut corners like that. I had no clue about the soundboard. They cheaped out and still we all break our back fixing them correctly. But the results can be stunning..I don't know it's just so boring seeing the campers anything past 1980. So boring! No character.
Deleted
Post by Deleted on Nov 22, 2015 10:08:44 GMT -8
Hello all I am kind of revisiting this thread. I wanted to know if half inch plywood will be ok in the rear where there isn't much walking at all. I found out that's what is in my trailer now and if I put thicker plywood I will be having a higher floor, and other problems. Mobiltec I know you said if you could do it over you would do a full inch. I hope half inch will be ok in a non traffic area.. thanks a lot.
Post by danrhodes on Nov 22, 2015 13:13:33 GMT -8
Hello all I am kind of revisiting this thread. I wanted to know if half inch plywood will be ok in the rear where there isn't much walking at all. I found out that's what is in my trailer now and if I put thicker plywood I will be having a higher floor, and other problems. Mobiltec I know you said if you could do it over you would do a full inch. I hope half inch will be ok in a non traffic area.. thanks a lot. My trailer didn't even have a metal frame in this area!. The bed is equally supported by the walls, so I would recommend replacing with the same material you remove.
Post by nccamper on Nov 22, 2015 14:49:40 GMT -8
I wanted to know if half inch plywood will be ok in the rear where there isn't much walking at all.... Are you sure it is a half inch? That seem thin even for Shasta. With that said, I agree that matching what's there makes sense. But if you are just doing under the bed, you could double up the entire area. 1/2" over the repair area and another 1/2" overlapping everything under the bed. Just a thought.
Deleted
Post by Deleted on Nov 22, 2015 15:46:37 GMT -8
Hello friends I have been busy all day. Thanks for your thoughts I will certainly do that then, put the same thickness as what's there. It's probably not what was there originally, owner before put down all new flooring. A HUGE plus for mine even though it still needs various things. The 1/2 inch is pretty solid actually, I'm not too worried. This back part rotted because of a faulty sealing of the window. I see a 4x8 slat of 1/2 inch birch plywood and that should be much better than pine. Any additional thoughts greatly appreciated, thanks
Post by mobiltec on Nov 22, 2015 16:41:57 GMT -8
I'm not following you here. Where is this 1/2 inch "slat" of birch plywood? What's a "slat"?
Deleted
Post by Deleted on Nov 22, 2015 16:49:31 GMT -8
Lol. Sorry Larry! I am referring to the 4x8 birch plywood at home depot I have in mind.
