novrmyhed
1967 Shasta 1500
Post by novrmyhed on Oct 22, 2015 17:39:31 GMT -8
I am getting ready in the coming weeks to rerun electric throughout the entire camper. I want 110....and I want it to charge a battery for 12v power. The 110 will power 3 lights, fridge, A/C, and possibly an instant hot water heater. The 12v will run 2 LED lights and the Fantastic Vent and possibly a cigar plug. Is this a good setup to handle all the above? www.vintagetrailersupply.com/Inteli_Power_4045_p/vts-567.htmDoes anyone have any other suggestions if not? Also, what would need done in order to possibly run the fridge off of the battery during drive time until hooked up to shore power? How would this be done or is it even worth it? The wife would like for things to start to get cold on the drive. Appreciate any input. Thanks everyone!
Post by vikx on Oct 22, 2015 22:36:09 GMT -8
You'll need a heavy duty 30 amp inlet or cord to start. To run at full power, you will need to be plugged into a 30 amp receptacle for sure. To run the A/C and water heater you will definitely need full power. They are amp hogs.
The Intellipower will be more than enough to run what you want. Just wire with proper gauge and pay attention to total usage.
I would not use the fridge with an inverter enroute. Get it cold before you leave and a jug of ice inside will do better without 12 volts.
Goes without saying, be confident and knowledgeable before installing electrical systems.
