sturgy03
Post by sturgy03 on Oct 17, 2015 22:44:00 GMT -8
Can I simply replace the bare aluminum ground wire attached from the trailer to the breaker box with bare copper wire?
Post by vikx on Oct 19, 2015 21:33:05 GMT -8
Yes, if the aluminum is in poor condition. I use the original aluminum ground if it's OK. No reason to change. Copper is good, too. 10 gauge or bigger on both.
sturgy03
Post by sturgy03 on Oct 20, 2015 7:38:07 GMT -8
Thanks for your info, my aluminum ground was right under a water leak from the celing so it definetly corroded and broke off. I am going to get a copper wire that looks the same. Its like a braided copper because the aluminum was like that. The copper will fit right in the same spot.
Post by bigbill on Oct 20, 2015 19:30:12 GMT -8
Braided copper ground wire is available from most ham radio suppliers in gauge equivalents of 7 to 12 ga solid wire
