Post by Ross on Sept 15, 2015 6:13:42 GMT -8
Has anyone attempted to repair or replace the waste valve/gate from a 1970 Shasta grey water tank?
Willing to bet that this part is obsolete.
Thanks for any help.
azshastanut
1957 Kenskill 16T
Post by azshastanut on Sept 15, 2015 10:23:37 GMT -8
As far as I know they haven't changed and are available at any RV parts dealer. Just changed one in a 1968 Prowler and they had them in stock. I also changed one in my 1957 Kenskill and they had all the parts, fittings, etc. in stock. I purchase parts from two dealers in Tucson who have been in business since the 60's. You can also shop on line for valves or valve parts. I have found some bargains on e-bay for sewer type fittings and rebuild kits.
Post by Ten on Sept 15, 2015 16:29:58 GMT -8
You mean this one? I can't for the life of me remember the manufacturer name on it, But I did google the hell outta it and found nothing. It had a twist lock to it. I do know that is was installed in ABS pipe and that is still accessible today. The Valterra valves are much the same blade-valve, only are lighter-looking. They are also made with a bayonet end with the nubs for connecting a tank hose to also. I'll try to find some of them for examples.
Post by vikx on Sept 15, 2015 23:38:02 GMT -8
White are Thetford, no longer installed in new rigs. These days, every US trailer has Valterra (black) waste valves.
Post by Ross on Sept 16, 2015 2:22:02 GMT -8
Thanks for the responses and posting the picture of the waste valve, Ten. However, after doing a bit more research on this valve, I did locate repair and replacement parts. DUPREE PRODUCTSThe original manual valve, known as the Owens Valve. Owens Products began production in 1964. It features a 6 lug Twis-Loc termination. Going to order a replacement Manual Valve Assembly today and I'll let ya know if all goes well with the repair.
man314
1964 Shasta 16-SC
Post by man314 on Oct 18, 2015 14:22:45 GMT -8
How did the valve itself attach to the bottom of the tank? Im replacing one on black water tank on 63 Shasta. Hard to get under to get a good look. My back water tank is fibreglass and seems to be in good shape. I assumed there would be some sort of flange to bolt into.
Post by Ross on Oct 19, 2015 5:11:23 GMT -8
My setup, the gate valve was attached to a Twis-Loc locking ring, that Dupree Products sells. I got my system all repaired, but haven't tested it, yet. Here is a link to my repair pictures of our original Owens Valve: Repairing my Owens Valve
gardnerk20
1964 shasta 16 scs
Post by gardnerk20 on Oct 30, 2015 4:23:13 GMT -8
I like he glue you made
Post by Ross on Nov 16, 2015 4:31:44 GMT -8
Thanks. It was cheap and easy to make.
