rockerarm
Post by rockerarm on Aug 6, 2015 7:36:46 GMT -8
Can anyone recommend a "frame to body" sealer to use when reinstalling windows and doors. My 68 Concord doesn't show any signs of ever leaking around the windows but I want to remove, cosmetically restore and reinstall them. And hopefully stay dry for another 47 years.
Thanks, Will.
Post by Ross on Aug 6, 2015 8:41:00 GMT -8
Butyl Tape is the only to go, for me. Been using it for years and never had leaks around vents, windows, doors, plumbing & electrical inlets, etc. It will even seal the threads on the screws, when reattaching.
Great stuff.
Post by ladywendolyn on Aug 6, 2015 9:43:44 GMT -8
I know some people put a bead of silver stuff on the outside edge over the butyl tape. I am not sure if this is a good idea or not. A couple of experts will soon chime in.
Post by nccamper on Aug 6, 2015 13:10:31 GMT -8
www.vintagetrailersupply.com/Butyl_Putty_Tape_p/vts-419.htmTry not to apply it when it's hot. One person suggested refrigerating it before putting it in place. Put it on the window then stick the window in place. Remove excess with a plastic scrapper. Tighten the screws but not to the point where all the putty is pressed out. Use double putty on vents or problem windows. Really easy.
Post by SusieQ on Aug 7, 2015 13:19:47 GMT -8
I know some people put a bead of silver stuff on the outside edge over the butyl tape. I am not sure if this is a good idea or not. A couple of experts will soon chime in. I use clear gutter seal on possible problem spots. It's very inconspicuous. Vikx has a thread that discusses various necessary evil sealing products but putty tape should do the job. You must pull your windows and j-rail to replace it.
Deleted
Post by Deleted on Nov 7, 2015 12:07:26 GMT -8
Hi there friends. I appreciate this thread because I am putting some new windows in ours, and was curious if it was as simple as using the butyl tape around the window as an effective sealant. I certainly know this was the original way it was done. Sounds like it's not too complicated putting in new windows besides having the correct cut out so you don't have a bunch of clearance. Haha but I am not totally sure. We want to do this right!
Post by nccamper on Nov 7, 2015 12:15:35 GMT -8
I don't see why a new window properly framed out would be sealed differently. Make sure the tape is seated completely by pressing or using a rubber mallet. If the space seems too much for one layer of tape, double it up. I did that on a front window recently.
Deleted
Post by Deleted on Nov 7, 2015 12:37:44 GMT -8
Excellent thanks, gives me confidence.
