chametzoo
![*](//storage.proboards.com/forum/images/stars/star.png) ![*](//storage.proboards.com/forum/images/stars/star.png) ![*](//storage.proboards.com/forum/images/stars/star.png)
1960 Mobile Scout
Post by chametzoo on Jul 31, 2015 15:40:20 GMT -8
Post by vikx on Jul 31, 2015 22:25:58 GMT -8
I am not into solar panels but yes, if wired correctly, the 7 way plug can easily charge the battery. Here is a picture of my "charger": ![](http://i189.photobucket.com/albums/z162/vikxphotos/Displays%20Parts%20and%20Pieces/12%20Volt%20Displays/Charger%207%20way%202_zpsu9jixtq4.jpg) Plug the trailer into the receptacle, and the battery is happy... same thing goes with a solar panel. I would suggest a charge controller when using a solar panel.
Global Moderator ![*](//storage.proboards.com/forum/images/stars/star_silver.png) ![*](//storage.proboards.com/forum/images/stars/star_silver.png) ![*](//storage.proboards.com/forum/images/stars/star_silver.png) ![*](//storage.proboards.com/forum/images/stars/star_silver.png)
Post by SusieQ on Aug 1, 2015 6:18:29 GMT -8
Zamp solar set ups have an adapter (quick connect to swap) that allows you to install a plug in the side of your trailer and instead of plugging into the battery with alligator clips you plug into the outlet.
Vikx, I like that charger. That's really cool.
chametzoo
1960 Mobile Scout
Post by chametzoo on Aug 1, 2015 10:57:19 GMT -8
I've got the controller built in to the 12v system, so charging from any source will be 'managed'.
I suppose I can just find a 'male' 7 way RV connector and cut the MC4 off of the solar panel lead and wire that to the 7 way appropriately. Connect the 7 way male to the trailer's 7 way female… and I'll be charging from the panel.
Post by SusieQ on Aug 1, 2015 14:55:25 GMT -8
Post by cowcharge on Aug 13, 2015 8:11:05 GMT -8
Chances are that the harness wiring is so small that by the time the power gets to the front of the truck it's not going to do much for you.
