davek
Post by davek on Jul 30, 2015 21:40:08 GMT -8
Is there a way to retro fit old single bulb (single filament) tail lights to double filament or dual bulb to be able to have trail lights and blinkers.
Thanks for any input
Post by vikx on Jul 30, 2015 23:56:56 GMT -8
The answer is maybe.
Tail light sockets tend to be bulb specific because of the slots and position of the bulbs. If you can retrofit modern dual purpose sockets and pigtails, shouldn't be too difficult.
I use modern light plates mounted on the old and have had good luck with that. Nowadays, LED is more readily available. You might check into using LED tail light guts?
