teacherman
Post by teacherman on Jun 2, 2015 20:03:18 GMT -8
Bought my first vintage trailer about 2 weeks ago. Been looking for a few years now and finally found something I believe I can do. I got a 1965 14' Ideal. Bought it from a gal who took everything out and started to replace some of the framing. Just about everything seems to be there. The biggest problem that I see so far is that she removed the back corner framing that had water damage. I would have liked it to still be there so I could use it as a template of sorts. Also going to have to redo some of her work. Can anyone suggest a good way of replacing this frame work. It is a curved section from top to bottom.
RinTin
Post by RinTin on Jun 3, 2015 6:16:10 GMT -8
Welcome teacherman, It sounds like the previous owner (P.O.) tried to repair the trailer by gutting it from the inside first. This method presents several difficulties, resulting in dilemmas such as what you find yourself in. It seems counter intuitive, but due to how these trailers were originally constructed, and how the structural integrity is integral to this method of construction, it is best to repair these trailers in the exact opposite order in which they were originally built, from the outside in. Once you get going in this order, it is pretty easy to figure out how approach the repairs. There are many, many threads here demonstrating this method. Take some time and peruse the forum to see how others have done this. Also, Larry (mobiltec) has a great website loaded with videos of nearly every aspect of trailer repair: www.cannedhamtrailers.com/One more thing, we like pictures here.
RinTin
Post by RinTin on Jun 3, 2015 7:54:56 GMT -8
Oh........... the radius edges are typically made by building up strips of 1/4" ACX plywood, ripped from the shorter 4' width.
Post by bigbill on Jun 3, 2015 8:26:50 GMT -8
If the other rear corner is still there pull the outside skins and you will see how it was built. Then match it on the other side.
Post by vintagebruce on Jun 3, 2015 8:38:42 GMT -8
to VTT. I agree with bigbill, if only one side was removed. If you do not have the mirror image side still intact, here is a thread to the Tin Can Tourists wiki site regarding Ideal campers. If you scroll to the bottom of the page there is a Facebook thread for the vintage ideal campers group. Maybe someone in that group made a blog of a 1964 14' rebuild, who knows? I do not Facebook so I could not open it. Our Member mobiltec has uploaded about an 8 minute plus Youtube video tour of a nicely restored 1954 Ideal if you just want to enjoy seeing a nice Ideal. www.tincantourists.com/wiki/doku.php?id=ideal#.VW8r92d0xMtwww.youtube.com/watch?v=GeUV8zZS5rQ
teacherman
Post by teacherman on Jun 4, 2015 7:35:44 GMT -8
Thanks for the input! The right rear is the side that she removed. The left rear inside the bathroom is intact. It looks to have water damage too. A couple of questions: 1. If the water damage on the wood is just darkened and stained but not necessarily brittle or soft does it need to be replaced? 2. When building the rounded corner with plywood strips should this be built and layered on the frame or assembled separately and then installed as on piece? I'm concerned about getting the curve right.
I'm sure I will have many more questions as I progress. Oh wait, one more! Should I pressure wash the outside before progressing with the frame or should I wait until I think the frame is done and all sealed up? I'm thinking I want to get some of the major dirt, grime and remaining paint off now when I know that any water inside won't be hidden and cause future problems.
Post by vikx on Jun 7, 2015 22:07:38 GMT -8
I don't think darkened wood all needs to be replaced, but be SURE it is not just good on one side with rot on the other.
The curve can be built in place; use the skin to copy the correct curve. (use original screw holes to tack it when needed)
If you are in a fairly warm dry area, a pressure wash won't hurt. If it's humid and HOT, I'd hesitate on a leaky trailer.
