chametzoo
1960 Mobile Scout
Post by chametzoo on May 30, 2015 12:29:56 GMT -8
Looking for a 12 volt LED low lumen output "standard" light bulb, warm white (classic shape bulb w/ standard E26 screw base). This bulb should be equivalent to about a 25W incandescent bulb, which is about 200-250 lumen brightness output. Many on line outlets now with 12V, LED, E26 base bulbs, but I can't quite zero in on this low lumen version. Maybe you all have sources for your 12V needs I haven't come across. Thanks.
Post by bigbill on May 31, 2015 7:13:00 GMT -8
Check Sears.com they have a verity of bulbs. Also you might go to a base adapter to use a different base blub.
RinTin
Post by RinTin on May 31, 2015 12:53:25 GMT -8
chametzoo
1960 Mobile Scout
Post by chametzoo on Jun 1, 2015 8:26:30 GMT -8
Rin Tin… yeah not too much 12v at Super Bright. Bill… I think adapters are the way to go. Opens up a lot more options. This sites got 'em all!: www.ledlight.com/led-converters.aspx… also a huge offering of 12V LED bulbs. Thanks.
chametzoo
1960 Mobile Scout
Post by chametzoo on Jun 1, 2015 8:57:35 GMT -8
