Post by universalexports on May 26, 2015 20:28:30 GMT -8
Saw this in a shasta for sale on ebay thought I would share, check out the AC setup, (notice the side air intake vent)
Post by vintagebruce on May 27, 2015 4:24:54 GMT -8
It's different...but I'm inclined to think the set-up is more for form than function. I'd like to see the drainage and exhaust set-up. Cute though.
Post by bigbill on May 27, 2015 14:32:38 GMT -8
If that side vent is supplying intake air to the condenser it is causing a low pressure inside the trailer which means hot outside air is being pulled in through every crack and every time the door is opened increasing the load on the ac unit.
Post by Ten on May 27, 2015 19:31:38 GMT -8
Good to see you around UE! Been a while.
